77 truck stops running
Old Mar 18, 2009 | 07:34 PM
RyAnIs1's Avatar
RyAnIs1
1977 f-150 cranks right up and will idol as long as i want, but when i start driving it for about 10 min i will shut off and then will not start. if i give it about an 1hr to sit then it fires right back up and then does the same thing. does any one have any idea?
Old Mar 18, 2009 | 07:40 PM
75F350's Avatar
75F350
Sounds like the ignition module.
Old Mar 18, 2009 | 07:50 PM
tlk50's Avatar
tlk50
Check the electrical connections on ignition/coil, starter silenoid, and battery terminals. Clean and make sure they are tight, especially grounds. Bad component (as 75F350 said) are loose connection most likely!
Old Mar 18, 2009 | 07:52 PM
RyAnIs1's Avatar
RyAnIs1
also if in park i can rev the engine, but as soon as i put in gear ang punch the gas it cuts it off but then starts right back. im sure they are two differnt problems but any idea on that?
Old Mar 18, 2009 | 08:00 PM
fmc400's Avatar
fmc400
MSEE
For the second problem, does it start back on its own or do you have to crank it over again?
Old Mar 18, 2009 | 08:06 PM
RyAnIs1's Avatar
RyAnIs1
i have to crank it over again
Old Mar 18, 2009 | 08:35 PM
tlk50's Avatar
tlk50
Ignition switch wiring in steering column possibly (I don't remember if that year was column are dash switch location) Could be carburater? What engine and carb you got and is it stock?
Old Mar 18, 2009 | 09:07 PM
RyAnIs1's Avatar
RyAnIs1
351 modified 400
edelblock 600cfm
the ignition is on the dash, i replaced the lock cylinder but not the wiring part.
Old Mar 18, 2009 | 09:59 PM
tlk50's Avatar
tlk50
Could be the power valve in the carb?
Old Mar 19, 2009 | 07:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Problem #1
The usual three step scenario of a failing Ford ignition module.
1) Module overheats, engine dies. Module cools down, engine restarts within a few minutes.
2) Module overheats, engine dies. Module cools down, engine restarts in an hour or so.
3) Sooner or later, usually sooner...module overheats...burns out, now the engine will not restart.
Besides the module, inside the dizzy is a stator aka pickup coil...the symptoms can be similar.
Most mechanics replace both at the same time. If the 1977 truck was not sold new in CA, it should have the "blue" module.
1U2Z12A199AA .. Ignition Module (Motorcraft DY893) / 1U2Z12A199AA replaced D9VZ12A199A.
MSRP: $113.62 // FTEpartsguy.com price: $61.36
D4PZ12A112A .. Stator (Motorcraft D1UA)
MSRP: $97.96 // FTEpartsguy.com price: $52.90.
Problem #2
If the engine bogs down, and/or hesitates from a dead stop or when punching it at speed, the accelerator pump diaphram and check valve need replacing.
This is a very common problem with Ford 2V carbs.
D5AZ9B559A .. Accelerator Pump Diaphram (Motorcraft CM2092) / Note: Fits 1975/79. 1962/74 is not the same.
C4AZ9576A .. Accelerator Pump Check Valve (Motorcraft CM825) / Fits: 1962/79.
Old Mar 20, 2009 | 06:57 PM
RyAnIs1's Avatar
RyAnIs1
i put the new ignition module in, so far it seems to be working, i have only done laps around my yard. i will test it out on the road tomorow.
Old Mar 20, 2009 | 08:54 PM
Tees77f150's Avatar
Tees77f150
Well, let us know, and what did you pay for the module and where did you get it?
Old Mar 23, 2009 | 06:16 PM
RyAnIs1's Avatar
RyAnIs1
Ited worked out good, that fixed the first problem, now i will work on the second problem. i got the module at advanced auto parts for 25.00
jyblood
Feb 24, 2012 02:30 AM
WoodHeat
Aug 16, 2010 03:52 AM
mudracin74
33
Jan 14, 2008 09:07 AM
barry1me
Modular V8 (4.6L, 5.4L)
Oct 4, 2006 04:01 PM
clipper1
Nov 16, 2005 02:16 PM
