Side door latch 95 van
Old Mar 18, 2009 | 07:05 AM
dadsgreenpsd's Avatar
dadsgreenpsd
Hi, I have a 95 van, with the double side doors, and the handle doesn't work any more. I did adjust the workings inside a bit, and got it working for a while, but it is pretty much worn out. It looks to be held in by rivets. Do these have to be drilled out, or am I making the job too difficult?
Thanks!
Old Dec 7, 2010 | 10:06 AM
jcn2004's Avatar
jcn2004
Hi there, anyone have any input on this? i have the same situation and would like to replace the handle.
many thanks!!
Old Dec 8, 2010 | 10:24 AM
dadsgreenpsd
I did end up fixing it. the outside latch is held in by rivets. The inside had a screw missing on the swivel part, which I replaced, and loctited into place. It has worked great ever since.
Old Dec 9, 2010 | 01:34 AM
neil 95 e350's Avatar
neil 95 e350
yes you have to drill the rivets out. i use Nutserts either in a plate or in the latch assembly and then use stainless button head or stainless flat head 10-32 machine screws to secure them as well as have them serviceable
Old Dec 9, 2010 | 04:57 AM
JWA's Avatar
JWA
This is a great idea Neil---wish I'd thought of it actually! Being in the auto glass biz I already have the rivets and tool used so commonly in this sort of R&R but your idea is by far the easier way to go.
crankbait321
Electrical Systems/Wiring
Feb 20, 2022 08:13 PM
genscripter
Mar 29, 2013 11:23 AM
sailorjohn
18
Mar 19, 2009 09:40 AM
k6mms
15
Sep 22, 2003 10:16 PM
