Does anyone have a delay wiper setup for sale. I've been through three of them off ebay and not been having any luck. The first two were from a 80 on which will not enable the washer function and the third one was the correct one but only the high speed works.
could do what I did and get a delay wiper unit from jc.whitney, it ties into exsisting controller.It is an extral switch to play with but worth the convience..
Do you still have the 80s? Now this is from memory but here goes. I have one out of a 85 F150 on my 77 F250 and it will work. When you unplug your wiper switch from you truck you should have two plugs to it. When you plug it into the pig tail from the black box on the 80s the large half moon shaped one will only plug in one way, and the smaller one with two wires will have a black/with green tracer ( washer motor) plug it in backwards and it will work. Been a while for mine but that is what I remember from doing mine. Hope you are not paying much for them on ebay I got mine from the junk yard for 3 bucks. A few years later I found one in a 77 F250 and took it and put it on the shelf.
Al-be-damned, it worked.... You are the man!! Thanks a million!! Now if I could only get my reverse lights to work.....
Glad I could help. They use to talk on here about pulling the pins on the 2 wires and reversing them for the washer but I found that it will just plug in backwards? .
