Aerostar IFS Progress Pics
Old Mar 17, 2009 | 08:38 PM
itsmywifestruck's Avatar
itsmywifestruck
Ok, so I can't figure out how to upload pics to my gallery, and I can't figure out how to put them in the post...So check out my Myspace link below to see pictures of my Aerostar IFS installation. Comments welcome. I still have to notch the crossmember so I can roll the steering rack back towards the cab, and then build the steering linkage. I have the column pulled out, and I have to cut the steering shaft off the original gearbox to complete the column and linkage setup.
MySpace.com - The Rob Ford Truck
ROb
Old Mar 17, 2009 | 09:00 PM
drof46's Avatar
drof46
Cool. Are you going to stick with the 14's or switch to bigger rims later? I like the C-clamp. I installed my rear sway bar this weekend and the only thing I could figure out to use was my small shop chair with a box on top to hold it at the right height. Still need to get around to doing the front this next weekend.
later
Old Mar 17, 2009 | 09:05 PM
itsmywifestruck
I want to try and get a hold of some 225/70/14's to put on those rims, and then put the sheetmetal back on and see if it looks right. I am wanting to run no wider than a 225 on the front, so hopefully I can do it with the 14's. I like the old school 14/15 combo.
ROb
Old Mar 17, 2009 | 09:38 PM
Customcab's Avatar
Customcab
Looks great; did you cut the front of the frame and bolt the clip from center of engine mounts?
Mitch
Old Mar 17, 2009 | 10:32 PM
drof46's Avatar
drof46
Thats great. I was thinking of going skinnier and shorter in the front on my project as well. My donor truck came with 4 almost new 255/70/15's. Will likely stick with this size in the rear to save a couple bucks on tires. Will have to change the offset to tuck them inside a bit more. Right now they stick out a little too much. Will know for sure once I get the box on. Keep up the good progress.
Old Mar 18, 2009 | 08:26 AM
itsmywifestruck
I did not have to cut the frame at all. The crossmember fits up under the the frame on the pickup nice and snug, and you just weld it in place. I did have to cut the motor perches off the subframe before it would fit under the truck, they were in the way. The crossmember bolts up under the vans...It has 3 long bolts on each side that go thru the upper control arm mounts, thru the frame and into the cross member. If you look at the pictures for the rear, I was able to use the rear-most bolt on each side, and that helped with mock up. My centerline I used on the frame was the hole on each side where the bumpstop was bolted. If you look at the inner frame picture you can see a bolt/nut in the frame. I used a very "scientific" method to find the location for and drill a hole in each side of the crossmember and bolt it to the frame to get it mocked up. I guess the big test will be seeing how well it drives. If you look at the upper control arms, this thing has a world of adjustability to it. The mounts are slotted for adjustment, and the control arms themselves bolt together, and are shimmed. Alignment should be a breeze, as long as the caster isn't to bad.
ROb
Old Apr 24, 2009 | 10:14 AM
crey's Avatar
crey
Any updates, news, fires, crahses?
i'd like to see how this turned out, and the ride as a result.
Looks fairly simple to do!
Thanks!
Old Jul 23, 2010 | 01:08 PM
scr8pin_f100's Avatar
scr8pin_f100
Hey all, I am also real interested in doing this swap..I found a guy locally at a Race/Rod shop who has made a kit for a "clean/easy" install of these things! He used a '53-'56 frame, but I think the kit would work for the mid 60's too..Anyways, here is a video I took of his set up..
YouTube - HillBillyF100's Channel
He is a good guy..Let me know if you would like his info..
scr8pin
Old Jul 27, 2010 | 01:21 PM
54TexasF100's Avatar
54TexasF100
I did the same aerostar front end on my 54 F100. See my PhotoBucket link.
Pictures by 54TexasF100 - Photobucket
MAP53
Jul 8, 2016 10:32 AM
RojoStar
Aerostar
Jun 23, 2016 01:09 AM
HillBillyBuddha
Jul 5, 2015 02:10 PM
noddaz
Mar 28, 2011 10:33 AM
