Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
upfitter switch help in stoon
Old Mar 16, 2009 | 08:08 PM
07gsxr's Avatar
07gsxr
i have a 2005 f250 super crew 6.0L
i am trying to hook up my sliptank pump and a plug in for my cell phone booster to the upfitter switches i have found the four wires behind the fuse pannle but i cant find the other wire my knowledge with electrical theres always a +/- so two wiers i can only find the ones behind the cjb any help guys
Old Mar 16, 2009 | 08:21 PM
96sherm's Avatar
96sherm
welcome to FTE... if no one in here can help, try the superduty forum (https://www.ford-trucks.com/forums/forum30/) or the 6.0L forum (https://www.ford-trucks.com/forums/forum107/) good luck and post up your truck!!!
Old Mar 16, 2009 | 08:22 PM
07gsxr's Avatar
07gsxr
will do thanks
Old Mar 16, 2009 | 09:25 PM
Snowking's Avatar
Snowking
Holy F%&?
cjb, upfitter switches, its offical Im only 21 and already technically out of date with modern technogies.
Even though my knowledge is hit and miss all I can say is find a constantly live wire
Old Mar 17, 2009 | 07:15 AM
96sherm's Avatar
96sherm
its accessory switches... known as upfitter switches in the SD's... the cjb got me stumped too...
Old Mar 17, 2009 | 11:08 AM
Drizzt's Avatar
Drizzt
does it need an isolated ground or can you not just use the cab/chassis ground?
Old Mar 17, 2009 | 07:46 PM
TheSilverBullet's Avatar
TheSilverBullet
There is only one wire from the switches. Just use a ground to the cab/chassis - wherever you find a place which makes a good ground point. The wires from the upfitter switches are just power on/off. Upfitter Switches 1 and 2 have a higher fused amperage with larger gauge wires. I have used these switches for accessories before and I also use one as a high idle too.
Old Mar 17, 2009 | 11:24 PM
preppypyro's Avatar
preppypyro
If all else fails, get out a test light and do a quick test if your unsure.
Welcome to Fte man!
icee
Jul 21, 2013 01:00 PM
brucedog
Jan 27, 2009 09:41 PM
leadhorse
Nov 21, 2008 08:35 PM
thegap1
Oct 30, 2008 11:29 AM
TXBDBY
Electrical Systems/Wiring
Jun 3, 2007 09:33 AM
