Shudder when turning from stop
Old Mar 16, 2009 | 12:43 PM
Dan Ward's Avatar
Dan Ward
My son has a 2006 f150 4x4 extended cab with the 5.4. When I was driving it last weekend I noticed a when turning from a stop it shudders a bit. Once straightened out it drives smooth. It felt a bit like the 4x4 was engaged but it wasn't showing on the dash. I was also wondering if it could be a bad CV. Is it possible that the 4x4 could be engaged? I am not familiar with the 4x4 on his truck, does it engage in the transfer case and front end?
Thanks - Dan
Old Mar 16, 2009 | 01:05 PM
fitz888's Avatar
fitz888
Does it have limited slip rear end.Sometimes the LS tries to stay locked and you get a little chatter from the rear end when you turn.
Old Mar 16, 2009 | 01:30 PM
Dan Ward's Avatar
Dan Ward
I have the chatter you described on my Excursion from the rear end. On my sons truck it feels like it's come from the front. For the 4x4 on my ex its the transfer case and hubs locking in and out. Looking at the 150s front end I see it has CV joints. Excuse my ignorance, but how does the 4x4 lock in on an 06 150? When I had my son drive forward when I watched underneath, both axles were turning to the front differential with 4x4 disengaged. Do the hubs lock in or out? I assumed that the hubs were always locked and it went in and out at the differential.
Thanks - Dan
Old Mar 16, 2009 | 01:39 PM
teamfalcon's Avatar
teamfalcon
There is a service bulletin for this. My 2004 had the same problem and took it in to get fixed under the warranty.
Old Mar 16, 2009 | 04:08 PM
FTE Trigger's Avatar
FTE Trigger
Seems awfully new of a model to have the clutch pack issue/Tsb...
Possible?! Maybe...?
Old Mar 16, 2009 | 04:10 PM
IHC's Avatar
IHC
A little bit is normal if it has a limited slip. It is mentioned in the owners manual ('04 anyway)
Old Mar 16, 2009 | 05:25 PM
wornout78's Avatar
wornout78
I had the CV go out on my 04 F150 and the only time I had problems with it was when I was going down the highway. It never caused a shudder when turning. I would bet that it's the L/S rear end staying locked up because on my truck that can make a pretty unnerving noise. As for it being 4x4, when my truck is in 4x4 it is pretty painful for the front end to be in gear and try to turn on hard surfaces, it's like the front end is just trying to hop across the ground. To check and see if its the front end being locked in, just put it in 4x4 at a stop sign and feel how it turns. If it makes the same noise or has the same feel then maybe that is your problem. I'm just throwing ideas out there...
Old Mar 16, 2009 | 05:27 PM
wornout78's Avatar
wornout78
Was this a recall type issue or something that was done under the original 3/36 warranty?
Old Mar 16, 2009 | 07:10 PM
mericanwit's Avatar
mericanwit
My POS 04 fx 150 had the rear diff shudder/vibration and had it "fixed" 3 times!!!!! Then the highway vibrations started and then the low speed/turning shudders started. Yup, the rear diff was "fixed" and then had clutch packs "fixed" what the frig are clutch packs anyway!?!??!?! And why oh why are there so many problems with a $36K vehicle? Arrgghhhhh......
Ok, thx for letting me vent... Good luck with the repairs and you might want to take a look at all the TSB's for these crappy trucks.
Old Mar 16, 2009 | 07:56 PM
jdrahush's Avatar
jdrahush
The only crap here is your attitude, and you should take it elsewhere for it is neither helpful nor wanted.
Sous
277
Jul 12, 2017 08:12 AM
abubba1
6.4L Power Stroke Diesel
Sep 27, 2013 06:12 AM
Fordbronco69
Jul 27, 2013 10:48 AM
FordLou
1997 - 2003 F150
25
Dec 23, 2010 01:00 AM
wreedZ71
2004 - 2008 F150
17
Nov 15, 2010 08:33 PM
