2004 Ford Expedition, Idol drops and revs up when in park and at a complete stop. <st1>Battery</st1> light blinks when idol drops to far then the truck revs up and down. Need helpful advice to target problem. I try to complete repairs on my truck myself by using the book made for my truck. I'm not a mechanic. I'm a woman with basic knowledge of general maintenance on vehicles and repairing parts on previous vehicles that have malfunctioned. Any help is greatly appreciated. I don't want to get stuck on the side of the hwy with all my kids. It's not fun. Thanks
Did the check engine light ever come on? Regardless, if you don't have/can't borrow a DTC reader, take it to an Autozone where they'll do it for free. If ypu get a code and Autozone can't tell you what the problem is, come back on the board and we'll figure it out. While you're at Autozone, pick up a can of MAF (Mass Air Flow) cleaner and spray the heck out of it - it doesn't hurt. It could be alot of things, so let's start with the easiest first. Come back and let us know whether or not you still have a problem.
Reason: correction
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 10">****** name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5COwner%5CLOCALS%7E1%5CTemp%5Cmsoh tml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> My check engine light came on immediately as the problem started. I went by an auto part store and they checked my codes. System 1 lean/ system 2 lean. Told me it was the oxygen sensors. Replaced the up stream and down stream oxygen sensors this evening and still having an idol problem. The only problem it did solve was the check engine light came off. I'm now thinking that it could be the idol control valve. Thanks for all your help.
I also thought it was my idle control valve - but before I bought a new one, I decided to 1st spend $5 on MAF cleaner as it certainly wouldn't hurt. Voila! Problem fixed. Check here on how to clean your MAF sensor. They have step-by-step color photos. Very easy to do. Just don't touch the wires. Clean Your MAF
If that doesn't fix it, then you might have a vacuum leak as cbradford mentioned. A little more involved in detecting. We can walk you through it. Come back and let us know.
