Transfer case question
Old Mar 15, 2009 | 10:27 PM
ddcjeff's Avatar
ddcjeff
I just picked up a 1983 F-100 4x4 that someone modified. It has a 460 lincoln motor in it. I am trying to figure what transfer case is in this so I can figure out the shift pattern it uses. I have pictures, but I am new here and not sure how to upload them. the number stamped in the case are
C1125
2N
Thanks in advance,
Jeff
Old Mar 15, 2009 | 10:32 PM
Franklin2's Avatar
Franklin2
1st off, is it cast iron or aluminum? Have you tried moving the lever?
Old Mar 15, 2009 | 10:44 PM
ddcjeff's Avatar
ddcjeff
Yes I have moved it, wont move all the way up, I found Nuetral, Pull back and it goes into 4wd then what appears to be 2wd. the case is cast.
Jeff
Old Mar 15, 2009 | 10:46 PM
ddcjeff's Avatar
ddcjeff
Did the 83 f-100 come 4wd? I know the stock motor was the 300 six
Jeff
Old Mar 15, 2009 | 10:53 PM
Franklin2's Avatar
Franklin2
Only the f150 came in 4wd. The 460 only came in the f250-up, and only around 83 or 84 f250's and up.
If it's cast iron, it's probably a np205 transfer case, although I think there was a np203 that was cast iron, and it was a full time 4wd case. These are all 70's transfer cases.
All the 80-up transfer cases were cast aluminum, and usually they were the np208, or the borg warner 1345. The np208 lever moves straight back and forth, while the borgwarner requires you to pull the lever toward your leg before it will go through all the ranges.
tbruz
Oct 28, 2015 03:20 PM
dougegoble
Mar 24, 2015 03:15 PM
mklemin
May 7, 2008 02:31 PM
SoArkSI
Nov 5, 2005 08:43 PM
mallen4
Nov 4, 2003 07:03 AM
