Fuel Pump questions
Old Mar 15, 2009 | 08:49 PM
jasonschwenk's Avatar
jasonschwenk
Fuel Pump questions
I subscribed to ALLDATA and 1st I highly recommend it to everyone.
I was doing some research and came to listings for 3 fuel pumps on my truck? Two of the listings said plastic fuel tank and steel tank. so I would narrow it down to two. Is that correct? One is in the fuel tank and another is where? I do not find a listing for where it is.
Also if I wanted to install larger injectors I know I need to upgrade the fuel pump. I have read all about FASS but was wondering what else there is available? What brands of pumps only are good if I were to go with another air/water seperator set up? Also would the upgraded fuel pump replace the stock fuel pump or go inline with it? Whether it is a FASS system or other and it goes in line with the stock pump where in the system before or after the stock fuel pump and water seperator?
Old Mar 16, 2009 | 10:08 AM
dchamberlain's Avatar
dchamberlain
Look up Horizontal Fuel Conditioner Module or HFCM. That should be the only fuel pump on a 6.0L truck, there isn't one in the tank. (Unless that changed between '03 and '04.)
Old Mar 16, 2009 | 12:55 PM
bismic's Avatar
bismic
The FASS system replaces the stock pump. Some folks have had issues w/ the FASS pump losing suction at 1/4 tank.
Air Dog is another choice. You would need an add-on pump along w/ the Air Dog filtration system, but you can keep the stock HFCM w/ it (IIRC). Most folks install a raptor pump w/ this setup.
You may get away w/ using the stock fuel pump even w/ upgraded injectors (Tex25025 would give you good advice on this). IMO, get yourself a fuel pressure gauge before any fuel system mods.
Old Mar 16, 2009 | 06:29 PM
jasonschwenk
Ah Ha! I did not realize that the HFCM was also the pump! Now I see and it makes much more sense Thanks.
So I pose the question....
Is it better to run the new pump in parallel with the stock pump? Has anyone tried this as a backup incase something happens? I would imagine that you would need a check valve in front of the stock pump to prevent back flow.
What do you think?
