I have a 1996 F-350 Diesel 4x4 regular cab longbed. I'd love to find a similar truck with an extended cab/longbed combo. I've seen it on F-250's. The only F-350's I've seen with this combo have been 2wd dualies. Was an extended cab optional on a 4x4 F-350 on the 1997 and down trucks?
If not, I may convert a 2wd over to 4wd. Just curious if anyone knows or not. I cant ever remember seeing one.
I believe you're out of luck. A quick glance in my 96 brochure only shows F-350 Supercabs dual rear wheel 4x2. I have the other years brochures also and can look, but I know that's the only way I've seen them in person too.
I took my 94 cab chassy and converted it into an extended cab for around $600. It took me 6 weeks working on it after work. I drove it for 3 weeks of the process. I bought a 86 F250 extended cab truck with no engine or tranny or box for $150 and cut both trucks in half. Added 22" to my frame, brake lines, fuel lines,wiring, and drive shafts. Cut both cabs in half and welded them together. RB
