how to take out back window
Old Apr 19, 2001 | 12:19 PM
murphydo's Avatar
murphydo
I have a 1984 f150 that i am parting out, but i would like to keep the sliding back window, I would like to know whats the easiest way to take it out. and the easiest way to put it back in another truck
1987 F150 2wd
300 inline 6 EFI
4 spd manual
159,000 and counting
murphydo@shu.edu
Old Apr 21, 2001 | 10:24 PM
fatforty's Avatar
fatforty
Hi, If you just want to take it out you could cut the gasket just slide a sheetrock (utility) knife up between the gasket and the window and go to town if you want to save the gasket you have to take it out from inside the truck. Use two small screw drivers pry the gasket down and push gently out on the window keep working the screw drivers around the window until you get the top and sides out then go in the bed of the truck and lift the window out of the bottom track. John
Old Apr 22, 2001 | 07:17 AM
jowilker's Avatar
jowilker
Hey John, A gasket that old should be replaced to keep down the chance of a leak IMHO. It wont leak in the truck now, but just change it out.
Whattyathink??
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Apr 22, 2001 | 08:38 PM
fatforty's Avatar
fatforty
Hi, thats why my first suggestion was to just cut it but if for some reason he needs the gasket I have changed them and if you clean them real good you can get them in without a leak unless the gasket is brittle. John
Old Apr 22, 2001 | 10:07 PM
Kenny's Avatar
Kenny
I agree. New seal is the way to go. As far as putting the window back in another truck......Take your new rubber seal, and install the metal trim first (if your truck has this). Next, you want to place the seal around the glass. wrap a piece of thin cord around the outside of the seal (in the groove). Have the two ends meet at the bottom, but leave a little extra past where they meet. Now you are ready to install. You will need a friend to help you. While your friend holds the window from the outside, go inside and set the bottom, and one bottom corner into place. Pull the cord towards the corner that is not set. this will pull the inner rubber into place. Push the window over toward the corner that is already set, and work the other corner in. Repeat pulling the cord and working each side in. Once bottom and sides are in, push the window down as far as it will go, then pull the cord to work in the top. I usually use weatherstrip sealant/adhesive, but I don't know if it is a necessity. I know this post is long, but I hope it helps you. Good luck.
Kenny
Old May 11, 2001 | 01:45 AM
karljay's Avatar
karljay
Old Jun 27, 2001 | 07:14 AM
holeshot's Avatar
holeshot
thinners rubbed into rubber with a rag
clean them so to speak also softens the
rubber to turn a crappy lookin rubber seal
into a good one providing as already
mentioned it is not cracked.
remember an origanal ford seal is always
better than aftermarket
p.s be carfull with strong metal objects
ang glass cause it can chip or worse.
usually if the window seal is rubber on both sides
u push it out from inside with your feet as you fold the seal
back get a mate on the other side to hold it as it comes out
if you want to save the seal.
but i am not to familiar with your model
murphydo
Oil & Lubrication
Jun 12, 2022 05:56 AM
murphydo
Jun 24, 2001 05:36 PM
murphydo
Apr 25, 2001 12:17 PM
murphydo
Apr 13, 2001 05:02 PM
murphydo
Nov 6, 2000 01:55 AM
