Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Millermatic 211
Old Oct 21, 2009 | 04:47 PM
winnipegf350's Avatar
winnipegf350
Sorry to bring up an old topic but I am thinking about a Miller 211 as well. How thick have you welded with regular wire. Can you comfortably do 1/4" without going to a flux core wire?
Thanks
Old Oct 21, 2009 | 07:59 PM
Ford_Six's Avatar
Ford_Six
I've only run flux core/dual shield through a 210 (previous model) once, to meet the codes for a job I was doing. I have welded 2" thick stuff with a Millermatic 211, the trick is multiple passes and bevel the edges quite a bit. I lay the bevels back at a full 45º, with about 1/16" to 1/8" of land depending on the material thickness, and lay in a really hot stringer of a root bead. After that, I turn it down a little and weave all the remaining passes. If there is access to the backside, I'll dig it out to solid metal with a grinder of burr bit, and weld with the same weave. This is the way I was taught in welding school for Electric Boat, and have been honing my technique for about ten years now.
Old Oct 22, 2009 | 05:49 AM
mitchntx's Avatar
mitchntx
Originally Posted by gfw1985
Been welding with it all week and I'm impressed. The auto-set feature seems to work great. I have a lot better, cleaner welds with more penetration and less blow thru. This is probably due to me not having old welder set correctly. With the $75 rebate and carefull shopping, I have less than $900 in it. Worth every penney.
I own a small fab shop. Build cages in road race Camaros and Firebirds.
I recently bought a Miller 212. It's identical to the 211 except it has a direct connection for a spool gun. And it has technology that automatically selects which gas to use when moving from torch to spool and back.
Its a very nice rig.
I found a place on-line that was running a 10% off sale and free freight. I had a voucher for an additional 15% off from a welding show I attended and there was a $100 rebate on the welder.
So, I was able to get it for under a grand as well.
After using a Miller 135 and and an old Lincoln 175, this will make a hack welder like me look like I'm a pro.
Uses the 44# spool of wire and comes with a 15' lead instead of the 12'. Has built in bottle rack ... lots of little things that make the machine easy to use and work with.
This genre of machine isn't cheap, but with some smart and creative shopping they can be affordable.
Old Oct 22, 2009 | 07:09 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I've had my 211 since March and am on my third spool of wire. Welded everything from 20 gauge to 3/16" with the .030 wire on 110v. I couldn't be more pleased. I don't weld anything thicker, but I'm sure its capable on 220v. Rated for 3/8" on 220v, but as Ford_Six stated proper welding techniques are the key. If there is a better all around welder for the money, I haven't found it.
idaho211
Garage & Workshop
15
Sep 1, 2015 03:56 AM
khadma
Garage & Workshop
Mar 7, 2014 06:20 PM
gfw1985
Garage & Workshop
Nov 26, 2013 09:43 PM
PAR34
Nov 13, 2013 07:48 AM
afinepoint
Garage & Workshop
Jun 8, 2007 04:22 PM
