Keyless entry Keypad
Old Mar 14, 2009 | 02:56 PM
the4by4freek's Avatar
the4by4freek
Does anyone know how to replace the bulbs behind the key pad? What is the bulb number. I have every other button light out. I know how to remove the door panels. Are the bulbs even replaceable or is it an entire assembly?
Old Mar 14, 2009 | 03:08 PM
rob188's Avatar
rob188
you would think they were replaceable but its ford and my guess would be you'd have to buy an assembly
Old Mar 14, 2009 | 03:41 PM
the4by4freek
So thats an assumption? I don't go off assumption I asked if anyone knew if it was or if it wasn't. This used to be the best site on the net to get ANSWERS to questions. I have owned Ford for a long time, I know about their assemblies. I was also told that it was going to take 6 hrs to replace a dash light bulb in an Expedition..... it took 25 min. Once again, I do not go off assumption. Is it able to be replaced or isn't it. It is in at least 2 sectors, i do know that much. The window switch lights cannot be replaced unless you replace the entire switch, I was wondering if this was the same way.
Thanks for the help Rob, but it was not the answer I was looking for. I could have made the assumption also, thats why I asked the question
Old Mar 15, 2009 | 01:22 AM
screwy's Avatar
screwy
I think they are LED's
Old Mar 15, 2009 | 10:54 AM
Ryan50hrl's Avatar
Ryan50hrl
I just pulled out all my door handles, (switched them to painted handles)....and there is no bulb behind the handle....so i'm guessing you'll be replacing the whole thing....
Old Mar 15, 2009 | 01:18 PM
Buck 1's Avatar
Buck 1
With that attitude it is a wonder anyone ever answers your questions................
Old Mar 15, 2009 | 01:27 PM
the4by4freek
I didn't have a bad attitude until I got a totally worthless answer. I have my own opinion about how to fix it. I also have extensive knowledge. I simply asked if anyone else had come across this problem and if it was an assembly or individual bulbs. I don't understand why someone would post an answer to a question that had no idea on how to fix it! Maybe now you will understand why I posted the way I did. I have been here for longer than you have and this site used to be among the best on the web for solutions and answers. Not so much now. Maybe too many new members, maybe not.
Old Mar 15, 2009 | 01:32 PM
Buck 1's Avatar
Buck 1
I guess I can understand your frustration, but your reply to someone who thought he was offering help was certainly not encouraging. Sorry for coming down on you...and it makes no difference who was here first; people try to help.
Old Mar 15, 2009 | 01:47 PM
the4by4freek
The correct way to try to help if you feel that you need to post is as follows:
I havent had the handles off so I can't tell you how they are lit. They might be LED's it might be an entire assembly.
This wouldn't have triggered a response from me. I already knew that.
Old Oct 24, 2009 | 05:36 PM
edsjr's Avatar
edsjr
Did you ever find an answer to this? Mine quit working and I would like to get them fixed but cant find any info on it.
Old Oct 24, 2009 | 05:58 PM
Gearbanger 101's Avatar
Gearbanger 101
Indeed. A little tact would go a long way.
Remember Bryan, you were the one who was asking us for help, not the other way around.
Old Oct 24, 2009 | 06:13 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes, the switches are LED lit.
You can go in there and remove the LED's and replace them with LED's from LEDs - underbody kits, cathodes, flexible LED strips, dome lights
great website. just depends on how good your electrical and soldering skills are
or maybe score one that is in decent shape from a junkyard, or buy a new one from Ford
Old Oct 24, 2009 | 07:13 PM
shorebird's Avatar
shorebird
I 2nd Tylus on the junkyard solution. 2nd Easiest/cheapest, but not so fast.
Buy from Ford, Expensive/fast (maybe depending on availability)
Repair not worth the effort.
Skip1970
May 2, 2011 03:20 PM
stellalola
Escape & Escape Hybrid
Apr 10, 2008 07:29 PM
brow603
1997 - 2003 F150
Sep 1, 2007 04:14 PM
Stacey
Nov 17, 2000 11:10 PM
