Headgasket replacement Q's?
Old Mar 14, 2009 | 12:18 PM
wd13's Avatar
wd13
I'm doing some research today to find out what is needed to replace my headgaskets. Last night on the way home it pressurized the coolant resivour and blew coolant all over the truck. Then I noticed the oil temp started to rise and the truck was bellowing white smoke with that anti-freeze smell.
Anyhow, was wondering if you guys could help me put together a generic parts list. I'm not sure what gaskets are reusable (if any), if the head bolts are TTY or not, etc. Also what are the torque specs on the heads?
Any and all help is appreciated. Thanks
<!-- / message --><!-- sig -->
Old Mar 14, 2009 | 11:03 PM
jdecker88's Avatar
jdecker88
Here is a Bump for you man
Old Mar 15, 2009 | 07:30 AM
Adam0331's Avatar
Adam0331
Bump........
Old Mar 15, 2009 | 08:22 AM
F350-6's Avatar
F350-6
Should be the same thing for the left side.
File Type: pdf
Old Mar 15, 2009 | 09:49 AM
mueckster's Avatar
mueckster
Good job Chris. Tried to rep you, but you know the drill.
loudford
Jan 30, 2013 07:21 AM
ClubDrof
6.4L Power Stroke Diesel
Oct 30, 2012 08:47 PM
Lil'Worthy
Jan 12, 2009 08:22 AM
josh04hdf250
Feb 26, 2008 11:33 AM
d0n_3d
1997 - 2003 F150
22
Feb 23, 2004 07:12 PM
