Sponsored by: Real Truck
99 F250 runing rough
Old Mar 13, 2009 | 06:27 PM
muleburrow's Avatar
muleburrow
Hi there
My 99 f250 runs ruff in 3rd and overdrive. more so in overdrive. After it warms up say 10-15 miles on the way home from work it runs like i have a bad cop but im not getting a code so i dont know were to start. Also when I get off the highway and sit at a light there is a skip in the engine. any help would be appreciated
TY Muleburrow<!-- google_ad_section_end --><!-- / message -->
Old Mar 13, 2009 | 07:59 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
OK, We need more info. What engine do you have?
EDIT: I just found out you have a gas engine. I don't know anything about that. Good luck.
Old Mar 14, 2009 | 05:58 PM
muleburrow's Avatar
muleburrow
Sry its a 5.4 330
Old Mar 15, 2009 | 12:05 AM
oct7brian's Avatar
oct7brian
I had the same kind of problem with my 99 V10. I thought I had trans problems but it ended up being several bad COPS and I NEVER got a engine code. In my case it only happened after it rained or was humid out. I found the bad ones by having it running and spraying one at a time with a water bottle to see which one started to short out. I ended up replacing 4 and have been good since.
muleburrow
Jan 21, 2009 09:00 PM
muleburrow
Dec 30, 2007 09:30 PM
muleburrow
Feb 3, 2006 09:44 PM
muleburrow
Dec 27, 2004 07:24 PM
