Tailgate cable load capacity?
Old Mar 13, 2009 | 03:29 PM
Damon_Tirerack's Avatar
Damon_Tirerack
Former Vendor
I want to put my 740lb ZTR mower in my truck for service. Will the cables hold the weight of the mower and the ramps, or should I remove the tailgate before loading? Last time I did I scratched it and don't want to if again I don't have to....
Anybody have an idea? 04 FX4.
Thanks.
Old Mar 13, 2009 | 04:52 PM
Still Smoking's Avatar
Still Smoking
I have loaded a polaris sportsman 4 wheeler in the back of my truck with ramps. Im not sure how much it weighs but I know they arent light. I would think you would be fine but dont hold me to it.
Old Mar 13, 2009 | 04:53 PM
Saleenguy's Avatar
Saleenguy
Thanks.
Remember at no time is the whole load on your tailgate.
Part of its on the ground end of the ramps, and once the front is in the truck bed, just the rear wheels are on the tailgate.
I myself have loaded heavier things than that into my many F150 trucks, and they have been fine.
Is that a guarantee your tailgate will be okay, NO.
But i doubt you will hurt it.....on average at most you have half the load on the gate at once, and since that is only about 370 lbs, i personally would not hesitate to do that to my truck.I tested my tailgate by having myself and some pals stand on the tailgate of my 2004 F150.
The combined weight of us 4 guys was 860 pounds, or roughly there abouts.
We did not break it.
Although I witnessed with my own eyes a nearly brand new toyota tacoma tailgate fail with just 2 guys standing on it in a parking lot.
it was a 2005 tacoma, and while both guys were pretty chubby, i bet they were no more than about 550 pounds combined.
I was shocked to see it break.
Old Mar 14, 2009 | 10:08 AM
FTL40's Avatar
FTL40
it took my 500Ibs motorcycle without even the hint it was a lot of weight
Old Mar 14, 2009 | 12:46 PM
jsoko's Avatar
jsoko
3 FAT Girl Limit
Old Mar 14, 2009 | 06:48 PM
Greg B's Avatar
Greg B
It's a Ford truck, ain't it? If I couldn't use my F-150 as a truck, I'd buy something that I could use like a truck.
Greg B
Old Mar 14, 2009 | 07:40 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
My 500 sportsman is about 750 lbs so you should be ok
Old Mar 14, 2009 | 07:45 PM
WhëëlMå1's Avatar
WhëëlMå1
I believe Ford rates the gates at 500lbs in the dead center (a very conservative figure... safe for the manufacturer). As mentioned above... at no time is ALL of that weight on the gate. I loaded my 600+lb ATV more times than I could count, on my old 06.
Old Mar 14, 2009 | 10:23 PM
Ford Fx4's Avatar
Ford Fx4
I have sat on mine many times with my buddies, easily 500+ at a time.
You should be fine.
Old Mar 14, 2009 | 10:31 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
c'mon guys...these aren't Tundras
that being said, the weight of a mower will be just fine
same here...almost 300 lbs by my lonesome self and the tailgate doesn't even budge when I'm moving about on it
Old Mar 14, 2009 | 10:38 PM
Snewt1's Avatar
Snewt1
I've had 2500lbs in the bed with the tailgate down. Enough load on the tailgate that I now have a 6" diameter 1" deep dent in the tailgate. So I would have to say the metal will bend before the cables will break....
Old Mar 15, 2009 | 06:47 AM
jsoko's Avatar
jsoko
Well tylus now I know your not on a SUB haha
join the NAVY and ride the WAVES
Old Mar 15, 2009 | 10:34 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I'm a big boy. big boned, but not fat
6'3"...and yes, I am a Submariner.
Old Mar 15, 2009 | 08:00 PM
jsoko's Avatar
jsoko
THANK YOU & the Deep SOUTH supports the
USN
USMC
USA
USAF
USCG
and if the big MAN falls we help
PS I can also pick up 3 FAT girls (one at a time)
SEMPER FI
Old Mar 15, 2009 | 09:31 PM
HankMurphy's Avatar
HankMurphy
Question
Do you remember where it broke? (Did the cables part, the thimbles at the end of the cables break, or did the truck bitt break off itself?)
Thanks for your memory,
