Engine change question
Old Mar 13, 2009 | 12:13 PM
asmitty91's Avatar
asmitty91
What issues would I have making the swap from 223 to 302 in my 62 F100 ?
Old Mar 13, 2009 | 12:37 PM
jowilker's Avatar
jowilker
Has been done many times, You will need a mounting system, Carolina Classics, Dennis Carpenter and others offer it, along with the engine, tranny and new driveshaft.
Piece o cake
John
Old Mar 13, 2009 | 01:52 PM
asmitty91's Avatar
asmitty91
Thank you sir for the reply. The 302 would be coming out of a 72 F100, can I use the motor mounts from that truck ?
Old Mar 13, 2009 | 04:50 PM
jowilker's Avatar
jowilker
You might be able to use the mounts after you weld in the conversion.
Your current set up is attached to the front of the engine and the front of the tranny. The new engine is a side mount and will have to have a conversion kit added.
John
Old Mar 13, 2009 | 08:30 PM
itsmywifestruck's Avatar
itsmywifestruck
You will also need to come up with a transmission crossmember. Someone will prolly know for sure, but you will prolly have to remove the trans crossmember currently in the truck.
ROb
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
