Sponsored by: Real Truck
pcv valve location 5.4l
Old Mar 12, 2009 | 04:15 PM
wrangler2520's Avatar
wrangler2520
I have a 2005 f250 with a 5.4l 3v can somebody tell me were the pcv valve is located is it in the valve cover or attached to the intake and what does it look like? I have pulled the hoses off both sides but I have not found it let
Thanks
Old Mar 13, 2009 | 12:21 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
On the 2-valve, it should be on the passenger side valve cover. It just slips into the valve cover. If the hose you pulled just pulls out easy, look at the end of the hose, that's the PCV valve. The other side shouldn't come out easy
Old Mar 13, 2009 | 04:24 PM
wrangler2520
mine is the 3 valve and it is not on the passenger side that I can see the passenger side has a pressed in fitting in the cover about 1/4" in diamerter with a hollowed hose with angle fittings that have a built in clamp. The driver side has the same set up but the tubing is 1" in diameter I pulled both off and you can blow thru both ends the fittings in the valve covers are not sitting in rubbergrommets like usuall they seem to be pressed into the metel of the valve cover that is why I was wondering if it was on the intake somewhere
Old Oct 1, 2016 | 11:56 AM
steelbill58's Avatar
steelbill58
I have the same engine in 05 F250. Changed the pcv heater element and I still have loud whining noise. Did you get an answer ?
Old Mar 20, 2020 | 01:40 PM
Sean Flynn's Avatar
Sean Flynn
If anyone is still looking.
The PCV is build into the driver side vaulve cover. You have to replace the whole valve cover to replace the PCV
Old Mar 20, 2020 | 06:20 PM
Djosbun's Avatar
Djosbun
I think he probably figured it out 3 years ago. Dont you agree?
-- Dave
Redcoat
Nov 23, 2008 04:26 PM
Mmaxed
Modular V10 (6.8l)
Mar 23, 2008 05:55 PM
DMBronco
1978 - 1996 Big Bronco
Aug 7, 2005 02:11 AM
azwolfman
May 28, 2005 10:36 PM
icy_wolf
Mar 25, 2002 02:03 PM
