I am in the process of upgrading my braking system on my 91 F350 CC. It has a 7.3 non-turbo. I picked up a hydroboost system from an 89 F450 including the master cylinder and hardware but the power steering pump was gone. I have been doing research on here about the needed pump with addition inlets for the hydroboost but I have not been able to find anything about using a saginaw pump with the hydroboost system.
So does anyone know if a saginaw style pump was produced that has the extra input for the hydroboost system?
If so, any idea what year, make, model or part number for one?
As far as I am aware the extra hose is just another fluid return line so can be "T`d" into the other return and so you can use the existing pump or whatever.
Well for once I was actually able to answer my own question. Here are some part numbers I located for a saginaw pump with two return lines stock. These were listed for a '78 Ford LTD
A-1 CARDONE Part # 208607 w/AC
ACDELCO Part # 36816002
A-1 CARDONE Part # 208606 w/out AC
Good post. I am stupid, I should have suggested that you scroll up a bit frome here to the pre-powerstroke page in the Diesel Section. They would love to hear from you and many of them have done the conversion you are planning. Good luck.
I had thought about posting there but I didn't want to put it in the wrong area. I spend a lot of time in there reading and learning, good info all over on this site!
