Check engine light comes on?
Old Mar 11, 2009 | 10:41 PM
shark1979's Avatar
shark1979
my light came on the other day. i had just pulled out on the high way and was standing on the go pedal. the light came on for a few min and then went off. it did the same thing twice after that but only when i was playing around. do these trucks have egt sensors in them to give you a warning that your to hot?
Old Mar 12, 2009 | 01:50 AM
ron's power stroke's Avatar
ron's power stroke
most likely it has given you a 1211 code..the HPOP couldnt keep up with your foot..very common code
Old Mar 12, 2009 | 01:56 AM
Kwikkordead's Avatar
Kwikkordead
What Ron said.
Old Mar 12, 2009 | 02:07 AM
liftedgrocerygetter's Avatar
liftedgrocerygetter
I get that all code way to often. LOL.
Old Mar 12, 2009 | 08:27 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Me Too! Im not sure what the code number is because I dont have a scanner but the light only comes on when I stand on it.
Old Mar 12, 2009 | 08:48 AM
03_PSD's Avatar
03_PSD
could it also be an over boost problem?
Old Mar 12, 2009 | 09:32 AM
Kwikkordead
Yes it could if you don't have one of these.
Overboost Annihilator
Old Mar 12, 2009 | 06:01 PM
shark1979's Avatar
shark1979
What is an HPOP (high pressure oil pump?). dont think it was an over boost issue. i can only get around 24 25 boost psi.
Old Mar 12, 2009 | 07:05 PM
megawatt00's Avatar
megawatt00
IIRC it is around 22-23 that the map trips the ses light.
Old Mar 12, 2009 | 07:14 PM
bruce51d's Avatar
bruce51d
yeah i'd say overboost, get the overboost annhilator and you'll be fine
Old Mar 12, 2009 | 07:18 PM
shark1979's Avatar
shark1979
the over boost what? where do i get one of them. does it hurt for that to happen. will iget more boost?
Old Mar 12, 2009 | 07:26 PM
megawatt00's Avatar
megawatt00
It is basically a pressure regulator that limits the amount of boost that your map sensor sees. It will not give you more boost. Some of our site sponsers have them.
Old Mar 12, 2009 | 09:46 PM
shark1979's Avatar
shark1979
so will it hurt any thing if i dont get one? light in the pocket right now, just got 6.0 tranny cooler, up pipes,ccv mod and ss brake lines all the way around!
Old Mar 13, 2009 | 02:43 AM
ron's power stroke
if it is a over boost it will defuel the truck..you will loose power till the boost drops bellow 22..not haveing the OBA isnt going to hurt anything...
Old Mar 13, 2009 | 10:03 AM
superduty4x4's Avatar
superduty4x4
That's what everyone says... mine doesn't seem to kick in until around 25-26. Never noticed it defueling either which is weird, always seems to run just the same. I think my truck is just a freak
scrooge
Escape & Escape Hybrid
Nov 23, 2013 11:08 PM
adammdennis11
Oct 11, 2013 09:03 PM
lragan
Nov 15, 2012 12:08 AM
Branny08
Apr 2, 2012 07:02 PM
diablo7308
2004 - 2008 F150
Feb 10, 2009 06:17 PM
