Sponsored by: Real Truck
It's Definitely Improving..
Old Mar 12, 2009 | 06:38 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea i had my truck tuned for my 35"s @ Ford.. in fact i was surprized the stock software would even allow for tires that large...
made a difference to my shift points, but still cant make up for the lack luster 3:73's im spinning, hahah...
p.s. how has the pitman arm been lately ? is that problem at least sorted ???
sure is nice to hear u found a good dealer to help you out... otherwise im sure u'd be pulling ur hair out after spending so much cash on that nice truck and having so many issues back to back...
Old Mar 12, 2009 | 06:53 PM
samurai's Avatar
samurai
I am very happy with my dealership. I am sure I drive them crazy being as detailed as I am with my truck, but they handle it in stride and always have a pleasant demeanor and help me.
I am still not 100% sure on my pitman arm. The body shop that put the lift on actually came out to Ford and took the old nut off and also the lock washer they put on and installed a brand new nut with no lock washer and torqued it down to 450 lb they said. 2008 does not call for a lock washer, but I swear my steering is looser today than it was yesterday. Hoping an alignment in the next couple of days will straighten that out. I hate to keep beating a dead horse on this issue but it seems to me (with my little knowledge) that since the tires were not changed after the lift that the steering should still be tight as it used to be.
Is there something else other than the pitman arm that could be causing loose steering? I have dual stabilizers on it but I THINK that just "masks" the issue.
Wish I lived in Cali or could afford to fly DCSpecial over to fix it!! haaa
I am the MOST ocd person you'll ever meet. I just want my ***** right.
Old Mar 15, 2009 | 11:23 PM
Loadre's Avatar
Loadre
Originally Posted by samurai
Drive shaft is finally straight according to Ford Tech with the help of a carrier bearing drop bracket. It DEFINITELY rides a lot smoother, HOWEVER there is an OCCASIONAL shuttering /stuttering between 20 - 40mph that has me CURIOUS!
What exactly was it doing? My truck has 22.5s on it and around 40-50 mph it will shake enough to jar your teeth out. Been trying to fix it for a while and wonder if this is the way to go.
Old Mar 15, 2009 | 11:35 PM
Steve_250's Avatar
Steve_250
Maybe I didn't see it anywhere but...
What is the name and location of the dealer that is taking good care of you?
We sure would like to know the good ones!
Old Mar 16, 2009 | 05:33 AM
samurai's Avatar
samurai
Classic Ford in Columbia, South Carolina
Old Mar 16, 2009 | 01:25 PM
Loadre's Avatar
Loadre
Help a man out here.
Old Mar 16, 2009 | 01:31 PM
samurai's Avatar
samurai
The "stuttering / wobbling" I THINK is 100% in the steering. As I would go faster it seems like the front tires are "floating" and thus giving me a "stuttering / wobbling" feeling.
Went back today to the shop and they retorqued EVERY nut and bolt that was touched when the truck was lifted. Overall it is much IMPROVED but it still feels a LITTLE loose while driving.
I don't care what anyone tell me, it was FINE before it was lifted....
Old Mar 16, 2009 | 06:58 PM
Furian's Avatar
Furian
You Keep What You Kill
I'm sure that there are many FTE members who would like to help you but based on the limited information that you have provided, I think that is a difficult task. All I know is that you put 22.5" wheels on your truck and while driving between 40-50 mph, you experience shutter. Here are a few bits of information that would be helpful...
1. What truck to you have? Example: 2005 F350 Dually 4x4 w/ diesel engine.
2. What did you do to the stock suspension to get those 22.5" wheel underneath the fenders?
3. Were you towing/hauling when you experienced the shutter? If yes, then how much weight?
The more information that you provide the better the response will be from the FTE members.
Old Mar 16, 2009 | 07:01 PM
senix's Avatar
senix
also did you do any steering stabilizers other than the stock one? I use dual skyjackers on mine.
Old Mar 16, 2009 | 07:42 PM
Loadre's Avatar
Loadre
was just searching through threads and thought his problem sounded similiar. Turns out its not.
Here's the lowdown on mine. 2001 crew cab long bed F350 dually diesel, automatic. The speedo is off but guessing at around 45 mph the rear of the truck feels like it's hopping off the ground. Suspension/chassis is pretty much stock. My buddy put the wheels on when he had the truck and said he added a leaf in the front I believe (the truck sits level). Has bilstein shocks all around which really did not help anything. Have played with tire pressures some to no avail. Was under it today and the driveshaft seemed to have quite a bit of play in the carrier/hanger bearing. Don't haul much heavy stuff in the bed, but it rides much smoother when pulling a 3 car hauler gooseneck with cars on it (2 cars, at about 3300 lbs a piece). Actually rides better with just the trailer itself.
Sometimes doing about 75-80 on the interstate if you come off the gas real quick it will start a violent hop/shake. If you ease back into the throttle it will start to go away. It seems to change in severity depending on the grade of the road (going up or down a hill).
I need to measure the driveshaft angles once it stops raining, I've all but decided thats the culprit.
Any suggestions man?
Old Mar 16, 2009 | 07:59 PM
Furian's Avatar
Furian
I recommend that you copy this post (your response) and start a new thread so that the FTE members can focus on your specific issue.
JonathanN
Dec 30, 2010 01:53 PM
therigwelder
Offroad & 4x4
May 29, 2003 06:53 PM
KONKILR
Dec 31, 2001 07:16 AM
