6" Lift Tech Question
Old Mar 11, 2009 | 08:27 AM
bigun72's Avatar
bigun72
Exclamation 6" Lift Tech Question
I Put a 6" lift on my truck and there was a rubber spacer on top of my strut thats about 2" thick , well when i put the lift on it i put that rubber peice back in there....... well now my lift is done my top a-arm is layin on my strut as u can see in the pics below. Should i take the rubber peice out or let it stay like it is? Some people are tellin me that it will be ok , I wanted to ask some of yall.
Old Mar 11, 2009 | 10:25 AM
jstnromero's Avatar
jstnromero
that geometry is all messed up!!!!
Is the truck on the ground or on a lift in those pics?
I would say it looks like you have a leveling kit installed with the lift.... if so what make and model lift is that and what leveling kit do you have on there?
I am sure others will be able to chime in on this as well....but in my opinion something needs to come out.
~jstnromero
Old Mar 11, 2009 | 10:32 AM
jam92102's Avatar
jam92102
~jstnromero
I was thinking the same thing. That maybe the rubber you were talking about was actually a lift spacer.
Old Mar 11, 2009 | 02:35 PM
bigun72's Avatar
bigun72
im guessin the rubber was a leveling kit , i took it out and it sits right and i can put my hand all back behind it .
Old Mar 11, 2009 | 04:40 PM
jstnromero's Avatar
jstnromero
good stuff....glad to hear that you got it all figured out
Old Mar 11, 2009 | 10:24 PM
mattd17's Avatar
mattd17
im curious too though... were those pics on the ground, or with the front off the ground? looks like it was off the ground, but cant tell.... if that was with the wheel on the ground, then you definately had to remove the rubber spacer.
Old Mar 11, 2009 | 10:39 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
was that spacer inside the coil-over, between the shock and the spring top?
there are 2 ways to level these trucks out. one goes ontop, the other goes inside. Sounds/looks like you have a Daystar leveling kit that was previously installed on your truck
it's weird though, because lots of guys have had success stacking leveling kits with Lift kits to achieve 8" of total lift...I guess that only works if you use the kind that stacks ontop, not inside
Old Mar 16, 2009 | 10:51 AM
bigun72's Avatar
bigun72
this was on top of the spring , them pics was with it sittin on the ground with all the trucks weight on it....as Tylus said ive seen trucks on here with a leveling kit and a 6" lift , i wish i cud have kept them in there because it sits high in the back with the add-a-leaf and the new block , and if i take the add-a-leaf out it sits way to low, i wish i cud level it out.
Old Mar 16, 2009 | 11:10 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
are you sure that is a 6" knuckle?
that is a whole lot of angle. most of the lift kits have OEM looking geometry
Old Mar 16, 2009 | 11:15 AM
bigun72's Avatar
bigun72
its got OEM looking geometry now that i took that rubber peice out..........
Old Mar 16, 2009 | 11:27 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
still looks slightly off to me...you've got a whopping 1.5" or so of downward travel before it hits the spring
do you have the Rancho or Bilstein leveling shocks installed by chance? or just OEM
Old Mar 16, 2009 | 11:30 AM
bigun72's Avatar
bigun72
OEM ........ i wanna put a leveling kit on it so it sits level , wat kind can i run ?
Old Mar 16, 2009 | 11:39 AM
bigun72's Avatar
bigun72
that last pic i posted is kinda took from the bottom angle , so it will throw you off a little bit
Old Mar 19, 2009 | 08:00 AM
JesseRohr's Avatar
JesseRohr
FTE Sponsor
Something is definately wrong there. I don't have those angles with almost 8" of lift on my kit.
Old Mar 19, 2009 | 11:39 AM
bigun72's Avatar
bigun72
mine is bout the same as yours , that pic was took from the bottom under the bumper up.....
