heat
Old Mar 11, 2009 | 05:35 AM
greenterror's Avatar
greenterror
Question heat
02 explorer 4.0 air blows through vents but its cold. im guees is the thermostat.
Old Mar 11, 2009 | 07:18 AM
F3Beam's Avatar
F3Beam
I'd guess probably needs a garden hose slipped on the heater core fittings on the firewall under the hood to flush out the heater core.
Old Mar 11, 2009 | 01:19 PM
marragtop's Avatar
marragtop
What does the temp gauge say? If it's not reading abnormally low, then I doubt if it's the t-stat. Could be a clogged heater core.
Old Mar 11, 2009 | 04:49 PM
greenterror
heat
guage is fine cooland is clean green maybe the blend door
Old Mar 11, 2009 | 10:00 PM
steve(ill)'s Avatar
steve(ill)
the blend door is an electronic motor actuated door that mixes the hot and cold airs to get the correct temp. the motor can be broke, the door can be broke, or the control **** or controler can be bad. pull the **** off the controler and see if it really moving the shaft, then go for the blend door.
Old Mar 11, 2009 | 10:16 PM
steve(ill)'s Avatar
steve(ill)
blend door is under the radio, behind the plastic panel
https://www.ford-trucks.com/forums/7...lend-door.html
