ok. got it figured out. the light blinked in this order: 6, 7, 6, 7, 1, 1, 1, 1, 1. i dont know how to put these codes together to know what they are or what they mean, but thats why im here.
also, i just looked up the codes, and i have no clue if im right, but from the looks of it, all it says is that my AC was turned on during the test and everything else passes... again, no clue.
Something must have gone wrong, codes should not be repeated. I ended up buying a $30 code reader because pulling the codes without a codereader is a pain in the ***.
ok. just checked em again. im goin to post them as tallies, and the pauses as back slashes. l l l l l l / l l l l l l l / l l l l l l / l l l l l l l / l / l / l / l / l... end test.
I have no idea, it does not make any sense to me. Maybe the AC being on is making it do weird things, that is the only thing I can think of. My suggestion is to try it again and make sure everything is turned off: AC, radio, fan, and lights. Godamn computers!
In this case, I would suspect a problem with the PCM. Check the ground behind the battery on the fender first. There is also a way to test the PCM, but I don't remember how off the top of my head. I tried a search but could not find it. You might want to look around for that, I know that Conanski has mentioned it. Good luck, hopefully its just a bad ground.
