new problem this morning...
Old Mar 10, 2009 | 05:16 PM
fkaster01's Avatar
fkaster01
I was driving to work... and everything was great. when i got off the highway, my temp guage went from straight up like it always is... to just above the low limit for normal range and it stayed there for about ten or fifteen minutes. then I shut it off. Driving home it warmed up, but only to the low limit line for normal range... then it eventually went up to about 1/4 the way through normal range, never back up to half though. The heat works fine, no noticeable difference, no coolant smell anywhere, the fluid level is exactly where its supposed to be, no leaks, no nothing... was thinking either the thermostat is bad or the sending unit went bad but i'm not sure. Any ideas???
Old Mar 11, 2009 | 12:27 PM
mastaplan2k8's Avatar
mastaplan2k8
my temp guage just wouldn't go past there on my old truck, everything worked fine and it never had any problems. Might just be the guage.
Old Mar 11, 2009 | 01:20 PM
qman's Avatar
qman
Your thinking matches mine. Replace both. They're both cheap and easy and you don't want wrong indications at the dash. And the last thing you want is a flaky tstat. If it sticks you can fry your engine.
Old Mar 11, 2009 | 04:04 PM
*2fords*'s Avatar
*2fords*
Thermostats are designed to stay open when they go bad. It prevents the engine from over heating. When they stay open the coolant continuosly circulates, collecting all the heat as is goes through the engine and on through the radiator. So the engine is alway cool. The guage would always read cool. If the thermostat was stuck closed, the coolant wouldn't circulate, it would stay in the block and boil, thus over heating the engine.
Old Mar 11, 2009 | 04:16 PM
qman's Avatar
qman
They why do parts stores sell two types? The last two times I bought a tstat I was offered the option of normal one or the one that will stay open if it goes bad (which costs more by the way.)
Old Mar 11, 2009 | 04:56 PM
1966Tbird's Avatar
1966Tbird
everyone i have ever seen was designed to stay open when it breaks
Old Mar 11, 2009 | 04:59 PM
fkaster01's Avatar
fkaster01
never heard of that before but i know it doesn't always happen that way, had one go bad on my first car and it stuck shut and i almost blew it up... just like anything else, only works when it wants and not when you really need it to
Old Mar 11, 2009 | 06:09 PM
1966Tbird's Avatar
1966Tbird
i guess all the motors i have built have been performance motors so that might have something to do with that
Old Mar 11, 2009 | 06:14 PM
Beastly's Avatar
Beastly
This happened to me in my little escort the summer before last. Thermostat stuck shut in the middle of the desert when it's about 110 degrees outside. I rolled down the windows, turned the heater on full blast (this was enough to bring the gauge back to normal), and limped it 40 miles home. (Boy, that sucked.)
I lucked out that I didn't damage anything except the o-rings on the temperature sender, coolant temp sensor, and the thermostat housing where it mounts to the head. Those were baked pretty good.
Last edited by Beastly; Mar 11, 2009 at 06:19 PM. Reason: not last summer... Time flies.
