i have a 79 f-250 and the windsheild washer motor recently quit working. I have never replaced one before. My question, How do i pull the old motor out, without damaging the plastic?
Good advice. I've been able to gently wiggle them out with a set of pliers. IIRC there are some slots on each side to let you get a grip. The new motor should only be around $12; I think the washer motor used on these trucks was used in every Ford for 20 years or so (don't quote me on that).
thank you for your tips on the motor being used on new models. I have an old 86 tauras behind the house that had the shares the same washer motor, that plugged right in.. Thanks for your help
Good advice. I've been able to gently wiggle them out with a set of pliers. IIRC there are some slots on each side to let you get a grip. The new motor should only be around $12. I think the washer motor used on these trucks was used in every Ford for 20 years or so (don't quote me on that).
I can't quote you, cuz that's not quite correct.
EOAZ17664A .. W/S Washer Motor ~ Includes Retainer (Motorcraft WG30) / EOAZ17664A replaced C9AZ17664A.
