2003 Ford Explorer Washer Fluid Pump
Old Jan 25, 2014 | 11:32 AM
mweaver644's Avatar
mweaver644
I have a 2003 Explorer Sport and the windsheild washer pump is not getting power. Owners manual does not show fuse or relay locations. Any information is appreciated.
Old Jan 25, 2014 | 03:21 PM
87 XLT's Avatar
87 XLT
The fuse & relay boxes are probably under the hood. Remove the tops & flip them over. Should be info on what each fuse/relay is wired to.
Old Jan 25, 2014 | 11:20 PM
shorod's Avatar
shorod
Fuse 2.23 (10A) in the Central Junction Box is for the washer pump and the relay is in the Auxiliary Relay Box #1.
If both of these are fine, the issue might be with the wiper contacts in the stalk or with the multifunction switch itself.
-Rod
Corinos
13
Dec 12, 2015 02:14 PM
99f250craig
Aug 21, 2013 03:23 PM
marragtop
Jan 24, 2013 06:44 AM
greenterror
Feb 4, 2007 10:52 AM
ricktoro
Electrical Systems/Wiring
Apr 28, 2006 08:47 AM
