7.3 trouble codes help!!
Old Mar 7, 2009 | 08:35 PM
kamaleon's Avatar
kamaleon
Angry 7.3 trouble codes help!!
Hey guys, my truck quit workign a few days ago and wont start. There are two codes but dont know how to tackle it or what to check/replace..
(P0603) = CONTINUOUS DTC P0603 INDICATES PCM HAS EXPERIENCED A POWER INTERRUPT IN KAM CIRCUIT. [KAM == Keep Alive Memory]
(P1660 OR P1661) = INDICATES THAT OUTPUT CIRCUIT CHECK IS HIGH OR LOW.POSSIBLE CAUSES ARE:HIGH SYSTEM
VOLTAGE, VREF CIRCUIT FAULT;
does anyone knows about this?
Old Mar 8, 2009 | 10:04 AM
F350-6's Avatar
F350-6
What are you using to pull the codes? What kind of shape are your batteries in? Make sure you've checked the battery connections and grounds for anything loose or corroded. Also check all your fuses with a test light.
Did the truck stall, or just fail to start one day? Does the wait to start light come on?
Old Mar 8, 2009 | 04:55 PM
kamaleon's Avatar
kamaleon
A friend of mine pulled the codes, im not sure what he used. An other friend of mine, mecanic, is coming tomorrow with his shop scanner to make sure on the codes.
batteries are about a month old, new high torque starter and starter solinoid about a month old as well.
the truck gradually lost all its power untill it shut off it self in a span of 400mile
Old Mar 8, 2009 | 05:19 PM
megawatt00's Avatar
megawatt00
This seems to point at the alternator. If It stopped charging the truck would have run off the batteries until they were dead. Sometimes if a battery goes that dead it may not come back.
Old Mar 8, 2009 | 05:57 PM
kamaleon's Avatar
kamaleon
alternator is good too, i changed the batteries because they were bad/not holding charge. In any case they are low now from trying to get the struck started, im charging them as we speak with a 12A charger.
Old Mar 8, 2009 | 06:14 PM
megawatt00's Avatar
megawatt00
When you said gradually lost power I assumed that you ment electrically. Could you describe it a bit more?
Old Mar 8, 2009 | 06:37 PM
kamaleon's Avatar
kamaleon
not electrical power, i meat engine power to move the truck. normally the truck can get to 100mph without a problem, initial powerloss was when i notice the truck couldnt go past 70mph, after a brief stop to check things it was very hard to start and it had very little engien power to move the truck and the top speed was reduced to about 50mph, eventually the top speed went down below 45mph and didnt have enough engien power to climb a very small hill in the highway. Once on teh side of the road and at iddle, the puttign the go pedal to teh bottom wouldnt even create teh slightest acceration, like if you were not pressing the pedal. Lastly it died on its own.
Old Mar 8, 2009 | 06:48 PM
F350-6's Avatar
F350-6
How old is your engine oil and is it full right now?
Old Mar 8, 2009 | 06:51 PM
megawatt00's Avatar
megawatt00
You'll have a better understanding when Kevin pulls the codes. If he is using an AE or simular he'll be able to see what is going on. By what your describing it seems fuel or TPS related. But without the codes and tests you can't knw for sure.
Old Mar 8, 2009 | 06:54 PM
kamaleon's Avatar
kamaleon
oil is about 7k right now and was going to change it upon arrival so its within change intervals. Oil level is full so it didnt use up any oil.
Old Mar 8, 2009 | 07:29 PM
F350-6's Avatar
F350-6
How did the engine run other than slowing down? Was it still smooth, or was it coughing and sputtering? Can you give us any additional information?
Old Mar 8, 2009 | 07:33 PM
kamaleon's Avatar
kamaleon
it was running a bit rough at idle, if i let it idle it would have died. at wot and barely moving it didn't felt so rough but definitely somewhat like a miss. It had a blueish smoke before dying and white/greyish when attempting to start it. Now thats its cold and changed the fuel filter it doesn't emit any type of smoke while cranking.
edit: coughing and sputtering its what i call rough.. so yep something like that specially at idle.
Old Mar 10, 2009 | 07:40 PM
kamaleon's Avatar
kamaleon
I just ran a few test on it with a genesys system scanner with software v2.0
Injector Control pressure: peaked at 2600
Injector Press Reg duty Cycle %: when keywas at the on position it read 15% and raised to 39-44 when engine was cranking..
so, do i have a high oil pressure leak and also starving for fuel??
PS. i disconnected the batteries and removed the chip, the only code in the pcm was the 0306 related to power failure, once deleted from the pcm no code ever came up after cranking the truck for 5-6 times. So, i have no codes now?!?
Old Mar 10, 2009 | 07:49 PM
Mike Norwood's Avatar
Mike Norwood
Are you getting any smoke out of the tailpipe when cranking? Just from the way it sounds, it sounds like there was a restriction in the fuel system that has progressively gotten worse to the point that it is not getting fuel now. Can you open up the fuel bowl drain lever and turn the key on and see if fuel comes out?
Old Mar 10, 2009 | 07:51 PM
F350-6's Avatar
F350-6
High pressure oil looks fine to me. Is the fuel filter bowl full of fuel? Does the wait to start light come on with the key? Did he monitor vehicle voltage while cranking? What are the outside temps there right now? Any smoke out the tail pipe while cranking?
I'd start with checking the fuel bowl for fuel and possibly checking fuel pressure (have to put in a gauge for that. The scanner can't read fuel pressure). Can you hear the fuel pump humming when the key is first turned on?
