7.3 trouble codes help!!
Old Mar 10, 2009 | 07:53 PM
Mike Norwood's Avatar
Mike Norwood
Yeah, what ^^^^^^^^^ he said. That's what I was trying to say, but Chris said it better and more completely.
Old Mar 10, 2009 | 07:55 PM
kamaleon's Avatar
kamaleon
no smoke comes out now, and fuel does flow into the fuel bowl. i dont know how fast is it supposed to flow but it does fill it up fine without the filter. The bowl does seem bit dirty, no deposits but walls and element. How can i get it cleaned?, a rag and brake cleaner?
Old Mar 10, 2009 | 08:02 PM
F350-6's Avatar
F350-6
You can clean the bowl, just keep 2 things in mind. The drain valve has o-rings in there that may not react too kindly to brake cleaner. They're cheap enough to replace, but watch for a drip if you use the brake cleaner. Also there is a little wire element at the bottom of the bowl that is fragile. If you break the connection on that wire (fuel bowl heater) it will blow a fuse that also powers the PCM so the truck won't start. Also make sure to flush the bowl with fuel to remove any residue before you stick the filter back in.
Try leaving the filter in the bowl, turning the key on, and opening the drain valve. Do you get a strong steady flow of fuel, or just fuel coming out of the drain? Any answers to the other questions I asked earlier?
kamaleon's Avatar
kamaleon
The pump does hum when the key is in the On position, WTS and SES are working. They come on then off then they turn off like normal. Temps here are 70 at the moment. I can check the pressure tomorrow, were does gauge go to test it.?
Old Mar 10, 2009 | 08:13 PM
F350-6's Avatar
F350-6
There's a port on the back of the fuel bowl that you can plumb the gauge into, but I'd try the opening the drain valve with key on trick first. No smoke means the injectors are not firing. The fuel pressure gauge may still come in handy since the stall and your no start might not be related.
Have you been keeping the batteries on a charger while you try and figure this out? If the battery voltage drops too low (like from extended cranking) the IDM will not fire the injectors. Even moderate fuel pressure with 2600 psi ICP should be enough to cause smoke while cranking, so we need to make sure voltage is good right now.
The voltage thing does not explain the way the truck stalled, so we still have to figure that one out, but let's see if we can at least get it to start for now.
Old Mar 10, 2009 | 10:23 PM
kamaleon's Avatar
kamaleon
i'll check behind the bowl and attach a gauge there.. any recommendation as which gauge? Is it possible to leave the gauge in place to monitor the pressure over time?
How much fuel should come out the drain valve when the key is on? Also, is there anyway to use a house and channel that fuel to a container? i have a large container underneath but it doesnt catch all the fuel that spills down the truck.
I have kept the batteries charge with 12amp charger when i feel they are getting low, the truck used to start even with two bad batteries, and with the new high torque starter it was much easier to start.
Im leaning to think the engine is not being fed the fuel it needs, if injectors are not firing could be idm? but no codes?!?
Old Apr 19, 2009 | 07:39 AM
kamaleon's Avatar
kamaleon
final update:
i took the truck to a shop, diagnosed was to replace injectors. $1700 later truck is back on the street.
Gruntface
Apr 7, 2012 12:03 PM
ozutah
13
Jan 12, 2011 07:48 AM
kawa
Jan 12, 2008 02:13 PM
linemanford6.0
Oct 7, 2007 09:43 PM
bhs2869
Feb 4, 2004 01:00 PM
