What could be wrong??
Old Mar 7, 2009 | 04:25 PM
sumbuddyloanmea.10's Avatar
sumbuddyloanmea.10
'01 FSD w/ 7.3L. . . 95,000 . . . just changed oil and air filter . . . just made a 1000 mile round trip with no problems. Have had the truck for several years.
Got back yesterday (Friday) afternoon from said trip, it sat in the driveway overnight, and this morning it would not fire.
Turning over just fine (until i RAN THE BATTERIES DOWN), but no fire.
It's a little chilly here today so I cycled it a few times . . . still not firing.
Then I gave it a little "gas" while cranking (this sometimes gets it to fire when it's really cold), but nothing!!
Diagnostics is damn hard I know . . . but maybe one of you have a spark of an idea what might be wrong?!
Old Mar 7, 2009 | 04:30 PM
new2diesel's Avatar
new2diesel
Try a CPS?
Old Mar 7, 2009 | 05:10 PM
Orezona's Avatar
Orezona
When you turn the key to "on" can you hear the fuel pump run?
Old Mar 7, 2009 | 05:12 PM
beer boy's Avatar
beer boy
id guess at the high pressure oil pump solenoid o-rings, if its not the glow plugs or the cps.
Old Mar 7, 2009 | 05:23 PM
Kwikkordead's Avatar
Kwikkordead
"Chilly" is a very relative term.
Where are you located?
My first thought is your glow plug relay has failed.
Old Mar 7, 2009 | 05:51 PM
clintbonnie's Avatar
clintbonnie
His profile says he is located in WY...Probably pretty darn cold..
Old Mar 7, 2009 | 06:43 PM
Steve_250's Avatar
Steve_250
Plug it in for a few hrs and see if she'll light up.
Old Mar 7, 2009 | 06:47 PM
nlemerise's Avatar
nlemerise
And charge those batteries up slowly overnight.
Old Mar 7, 2009 | 06:57 PM
sumbuddyloanmea.10
Yes on the fuel pump . . . white smoke came ut.
CPS?
34 degrees is fairly cool . . .
Glow plug relay??? Wahat was that test you can do?
Something about a jumper accross two terminals somewhere?
Old Mar 7, 2009 | 07:26 PM
nlemerise's Avatar
nlemerise
CPS?
I'm betting one of two things: batteries or glow plug relay. So the batteries, unless they are old, will benefit from a nice low amp charge overnight. Then turn the key to the RUN position, go under the hood and you will see a relay on the passenger side of the engine (to the left of, and slightly behind, the fuel filter). If you have a test lamp or a multimeter, touch each of the large posts and you should see 12+ volts on both posts. If you don't have a test light or multimeter, just take a screwdriver and jump the two large posts for about 30 seconds or so (you will hear/see a little spark when you jump the posts with the screwdriver). Then try to start the truck.
Old Mar 7, 2009 | 07:31 PM
sumbuddyloanmea.10
I'll do it in the morning!!
Thanks all........
How long do the relays usually last?
Old Mar 7, 2009 | 07:35 PM
nlemerise's Avatar
nlemerise
Thanks all........
We've seen them go bad quickly and some last years and years. If you need a quick, cheap one NAPA has the GPR-109 for cheap ($29?). If you tell them it is for a Ford 7.3 they'll give you the GPR-110 for mucho $$$ ($100?). They are identical relays, just twisted 90 degrees. It will work on your truck...guaranteed.
Old Mar 7, 2009 | 07:36 PM
sumbuddyloanmea.10
Coooool
Thanking you . . .
Old Mar 7, 2009 | 07:37 PM
Steve_250's Avatar
Steve_250
I replaced mine in my '03 with a Stancor, simply because I knew it would eventually fail.
It was a straight-forward swap.
Here is the link:
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Bookmark the index of this site and go through it, fantastic info you WILL need. He is one of our members.
Old Mar 7, 2009 | 07:39 PM
sumbuddyloanmea.10
I've replaced one before. In fact, I seem to remember buying two of them so I'd have a spare. Hope I can find it!
