Sponsored by: Real Truck
Detailing Tip for Tires
Old Mar 7, 2009 | 11:07 AM
high ho silver's Avatar
high ho silver
I have a simple trick I have been using over the years that I wanted to share with you guys that are as **** as me about keeping your stuff clean. I have always hated trying to use the tire shine after washing and drying everything only to get it all over the rims which I have to wipe down a second time. Then it has a slick coating that all the dirt sticks to so I came up with the idea of having something cover the rims while I was spraying the tire shine. On a '99-'04 with 16 inch rims, cut a round piece of cardboard exactly 17 1/4 inches. It helps to put a handle in the center. Now when you spray, you can cover the rims and not get any on them. I have used the wipe pads too but they seem to wipe off as much as you put on. Enjoy shining your tires.................
Old Mar 7, 2009 | 11:46 AM
SGnAZ's Avatar
SGnAZ
Good tip.I'm going to try that.
Old Mar 7, 2009 | 11:48 AM
dew the thunder's Avatar
dew the thunder
You can actually buy rim protectors from Summit I think for this purpose. I've seen a couple guys use them at car shows.
Old Mar 7, 2009 | 12:43 PM
high ho silver
I'll be dang....I need to get out more. Somebody beat me to a patent on my piece of cardboard. LOL...I'm missing so much of this world working all the time. But working is just about to get my two kids through with college. Maybe in a couple of years...
Old Mar 7, 2009 | 02:17 PM
ReAX's Avatar
ReAX
They use plastic and have been around atleast 8 years. I think KleenWheels makes the nicer version with the handle and trim lines so you can fit them to your wheels. I believe Blitz makes a set as well.
Old Mar 7, 2009 | 05:57 PM
NorCalBusa's Avatar
NorCalBusa
[Rant]
I think tire dressing is about as **** as a thing can be...especially on truck tires...not that there's anything wrong with that. Its simply as ghetto a look one can achieve- as if you don't have sufficient money to actually have a nice ride, so here let's spray some shiny crap on the tires so looks good- "My windshield is cracked like a $3 hooker and I can't afford to fix it, but I got's my tires all da bling!".
[/Rant]
Old Mar 7, 2009 | 06:27 PM
ReAX's Avatar
ReAX
Not all products are shiny. While I think super glossy fluids like Black Magic look good, I use products that leave a more natural rubber sheen, mainly Formula 303 or Mother's reflections tire care. Tires need to be cared for, particularly if your like me and a set last 10+ years. UV blockers help prevent dry rot and cracking, so it's not a bad thing to do to tires.
Old Mar 7, 2009 | 06:56 PM
boxcar1974's Avatar
boxcar1974
Jeez I never thought about posting that trick here.
I have been using the cardboard trick for years.
I have 18's on my 03 and I cut the center also. My caps are tapered and the cardboard fits snog for hands free use.
Old Mar 7, 2009 | 08:16 PM
high ho silver
Originally Posted by NorCalBusa
[Rant]
[/Rant]
Its not all about the shine...it also helps protect from the sun's UV rays. Let them sit long enough without protection and they will turn brown and start to get spider cracks.
Old Mar 7, 2009 | 09:16 PM
bayou barataria's Avatar
bayou barataria
There is a new tire gel applicator at auto zone, the bottle has a big sponge on one end for the cap that is curved for the tire, it works pretty good, just squeeze and apply. No fuss no mess.
Old Mar 8, 2009 | 01:32 AM
jlmotox's Avatar
jlmotox
I too am **** about cleaning my wheels and tires! if the rest of the truck is shining the wheels and tires have to shine!
another tip is to make sure you clean the side wall of your tires, I like Simple Green and a scrub brush. you have to get all of the old crud left over from the last time you put on a tire dressing. simple green is also great to use on your wheels. I prefer to use the meguires gel and a curved applicator...the cardboard is a great cheap idea!!!! will try that for sure!
Old Mar 9, 2009 | 12:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
One thing I've found about most "shine" products, like Armor All, tire stuff, etc.
It seems that once you use it, you HAVE to use it to keep the surface protected.
I've almost never used tire shine, maybe once or twice, and the tires soon after started to get that "really dry" look to them.
Other tires, I never did anything to them except soap them down every time I wash the vehicle, and no dry-rot over 4-5 years of time.
Go figure.
The tire shine stuff IS good, however, for removing wax from black body plastic
Old Mar 9, 2009 | 02:02 PM
joe chevy's Avatar
joe chevy
No offense
but make the kids clean the tires lol
i know its tough to get them to do anything i got 3
Old Mar 9, 2009 | 02:05 PM
brian42's Avatar
brian42
Veteran: Navy
I use the Meguiar's tire goop. It's got UV protectant since I have to park outside all the time...my rig is too long for the garage
Old Mar 9, 2009 | 06:29 PM
DAVE67FD's Avatar
DAVE67FD
I like the original Armor all. it's not too greasy and i apply with saturated rag so i don't have to get spray on the rims. It doesn't give it that "wet" look, just a clean, bold look. I do the the Simple Green to wash the tires/rims as well between applications.
