New to the 6.9/7.3IDI and am wondering what the differences between the IDI and Power Stroke are?.
I recently picked up a 86 F250 SuperCab Dually Longbed 4WD 6.9 4spd with 3.55's that is Rust/Rot Free and we are going to resto-mod it to pull our toys... Race cars in the summer and Snow toys in the winter.
I've have a 91 F250 7.3IDI 5spd with 4.10's as well but DOT refuses to sticker it do to excessive chassis rust/rot not to mention the cab and bed. (It is REAL BAD!)
I've been thinking on putting the 7.3 and 5spd in the 86 and adding a Banks Sidewinder, Should I, Or should I find a Power Stoke instead.
The 7.3 has in excess of 300,000 Miles with a KNOWN HISTORY and is SOLID!, the 6.9 is a Jasper Reman that I know nadda about. I plan on contacting Jasper and finding out when it was remaned.
SAme here on the jasper thing. But in MHO the IDI's are the better motors. They are alot simpilar to wotk on (no electronics). If you want alot more detailed info on the IDI's go to the 6.9 7.3 IDI forum, there are a lot of very knowledgeable people there that can give much more info.
It depends on what kind of truck Your looking to build. IDI's are dependable and inexpensive to repair and maintain. But are not Power Houses. The PSD will make a bunch more power, but will be more expensive to repair/maintain.
Of course I want it all ... And for nothing!
It'll pretty much be a road truck pulling a 38' goose neck.
I do want to build the motor, Not sure of the HP/TQ goal yet, I suspect ~400hp/1000FtLbs if it can take it. (I'll ask the IDI forum for these Q's)
I really don't want the electronics either, but I need more power, both the 87 (6.9) and the 91 (7.3) Choke on molehill's with two stock cars, tools and spares.
We are a bit off topic though ... My OPQ was "What are the differences between the IDI and Power Stroke"
For example: are the 7.3IDI and the 7.3PSD blocks/cranks/heads/valve train ... etc. the same. I know the PSD is electronic and turbo'd, but what other differences are there.
The basic difference is the IDI is indirect injected (injector behind intake valve). The powerstroke is direct injected (injection direct into the combustion chamber). The IDI has small cheap reliable mechanical injectors. The powerstroke has larger, expensive, oil fired injectors. The IDI is all mechanical, while the powerstoke is computer controlled.
I used to own a '93 factory turbo'd 7.3 IDI w/5speed, 4.10 gears (now owned by my son). The factory turbo system was a detuned ATS system. I changed the waste gate and exhaust. Bumper the mechanical pump timing up a few degrees, made a huge difference in power.
With the mods, it pulled a 14k fifthwheel quite well. I just hoped the trailer brakes never failed, as the truck braking with the trailer was marginal.
The PSD is electronic but don't let that scare you. With a $250 Aeroforce Scangauge or Auto enginuity for a computer you can pull codes and do a Buzz test and contribution test as well as monitor live data from the PCM. With that info at your hands and the help of the OBS PSD forum you can fix anything you have the tools to do. Pretty much if you feel comfortable doing any work on an IDI you can do it on a PSD.
The PSD is really quite simple once you understand the system. And the power potential is pretty darn good too. The 7.3 is an old engine but there are still new parts and mods coming out for it all the time and many people pushing its limits and rebuilding to keep making more power. More than you ever need in a daily driver.
BTW 400hp is not a cheap endeaver no matter which engine you choose and it is way more than enough to pull your trailer!
To swap in a PSD you will pretty much need a donor truck with all the wiring, dash, transmission (unless you are using a ZF) and the PCM and IDM.
Also, the IDI/PSD are completely different motors, and nothing exchanges between them.
Thank you ... That is what I wanted to know. It is a complete redesign!
Originally Posted by fonefiddy
If Your truly looking for 1000 Ft Lb's, Your going to have to mod up a PSD. $$$
That 1000FtLbs was just a number pulled from a hat, I really don't know what I want, I'm going to start adding and probably never quit! We are a racing family and it wouldn't bother me a bit to be able to roast them posi duallies leaving the track after a nice one two finish! YeeeHaaa! (I do realize that is a bit far out there)
I am far from scared of electronics! ... I don't want the conversion hassle and incorrectness of the fit and finish.
An IDI NEEDs a Turbo for real power. New kits are in the $2K range.
I'm a looking ... Not sure if it'll be ATS or Banks yet, I'll dig some more on that subject in the IDI forum. Yes I do monitor it as well!
No its his job, he's a marketing guy or something, he's really helpful in tracking down parts, especially because Banks doesn't offer just a turbo kit, but instead a kit that has everything, so he can break down the kit and get prices.
Why not sell the trucks you have, take that money and the 2K a IDI turbo setup will cost (if thats the going rate) and buy a PSD. Shoot with the money from both trucks and 2K on top you could get your hands on a Super Duty. I am all about the OBS but you have less upgrades needed on a SD to get the power. They have larger injectors and an intercooler.
