Bellowed Uppipes
Old Mar 7, 2009 | 07:41 PM
jdecker88's Avatar
jdecker88
I am with mike which Joe are we talking about the one that helped out a FTE member when he broke down or Izzy?
Old Mar 7, 2009 | 07:43 PM
ron's power stroke's Avatar
ron's power stroke
it was Joe (rjmjr78)
Old Mar 7, 2009 | 08:03 PM
big poppa's Avatar
big poppa
Me too Mike and Chad..stock here....Nice explanation Roland and much needed mod for these trucks...
Old Mar 7, 2009 | 08:11 PM
beanhead6D5's Avatar
beanhead6D5
Runnig stock on mine also.I replaced the up pipes and donuts when I did mine.that was alittle over a year ago.So far so good.
Old Mar 7, 2009 | 08:35 PM
wilbur996's Avatar
wilbur996
Forgive me for this possibly dumb question. Do you have to remove the turbo to do this work or does everything come off from the back/underneath the truck. Does not look like a fun project.
Old Mar 7, 2009 | 09:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
No, yes, and yes from what I hear. I would not pull my turbo to do it. I have heard it is much easier with the tranny out, but I wouldn't go that far either. I will comment if and when I have to do this. Until then, we learn from those that go before us or repeat their mistakes.
Old Mar 7, 2009 | 10:21 PM
Bigfwt04's Avatar
Bigfwt04
Don't really have the funds but after seeing Roland's pipes I am going to go ahead and do the Bellowed Up-pipes before they go up again.
Old Mar 7, 2009 | 10:26 PM
beanhead6D5
Tim,if you soak all the bolts with BP blaster or some micro mist penetrating oil the night before it makes things go easier.It was a pain for me cause I was short on time when I done it,so everything went wrong.
Old Mar 8, 2009 | 07:39 AM
wilbur996's Avatar
wilbur996
Thanks for the replies guys.
Old Mar 8, 2009 | 09:34 AM
mueckster's Avatar
mueckster
Originally Posted by miller_feed
Just talked to Roland and he had a harder time getting the up-pipes on then we had with mine. He will finish tomorrow. He did get Joe going after working all night last night. I think Joe left at 5:00 this morning. Roland is picking up his wife at the airport in Houston tonight, then I am sure he will get some sleep.
The baby's butt dowel pin was being a "butt" about lining up to seat the flange. I ended up almost taking the bolts completely out of the exhaust manifold flanges to get things right. Then, she fell into place. I got the exhaust and turbo mounted and tightened before going to the airport. I will be finishing this job up before lunch.
I haven't see my wife for 3 weeks and I want to spend this evening and tomorrow with her.
I did finally get some sleep last night. Joe and I got a late start on Friday. We were still waiting for "Mr Brown" to deliver our much needed parts. He arrived after his injector showed up and we went to my work to pick up the uppipes. My shipment had been delayed and was still sent there and couldn't be intercepted.
I will tell more about Joe's truck in his "AE scanner" thread. Long story short another trip to town was in store for us.
Old Mar 8, 2009 | 10:53 AM
mueckster's Avatar
mueckster
Plans changed. Will be havin' lunch with the wife and in-laws first. Get some errands done and THEN work on finishin' my truck. Family is also important to me and right now they rank first.
I will update when all is done and I take my test drive.
Old Mar 8, 2009 | 12:00 PM
megawatt00's Avatar
megawatt00
Roland enjoy your time with the Mrs. 3 weeks is quite a while. We can wait!!
Old Mar 9, 2009 | 12:43 AM
  #28
mueckster's Avatar
mueckster
Got finished with turbo install earlier tonight. Test drove. Lots more whistle. Does seem to accelerate quicker due to faster spooling. EGTs lower. Boost numbers are a bit low. Everythings tight. Need to tighten up the wastegate more. Will try it out tomorrow. Need to drive in the daytime to evaluate things more. Pleased with the outcome so far.
Old Mar 9, 2009 | 07:35 AM
  #29
megawatt00's Avatar
megawatt00
I'm glad that your pleased with the outcome so far Roland. You had a busy weekend between the two trucks!
Old Mar 9, 2009 | 09:25 AM
  #30
mueckster's Avatar
mueckster
Thumbs up Turbo Install.....Done!
I finished up the turbo install last night. It was after 10pm when I got her up and running again. I had a little trouble with 4" hose to the turbo inlet. I don't know why the can't make those things fit right. The spider sits forward slightly and caused the hot IC pipe boot to come in contact with the engine pull loop bracket. I took one of the bolts out to pivot it around for clearance. Problem solved. The hot IC even now has more clearance away from the air filter tube on my AFE and is a plus. I put the Turbo Master WG Controller linkage on the BB turbo. I had it it adjusted a little tighter than what it was on th stock turbo. Boost was low; barely hit 20 in 80e. I came back a got a wrench to adjust the WG. I tightened it down some more. Now it was like 22-23psi. I tried it in 120r and got a couple more #'s. I stopped again and cranked the adjustment all the way down. I think it went 26psi at the max. Better. It was hard to watch the gauges, at night, speeding down a back country road going over creek bridges AND running outa road. I have a little "tweaking" I can do. I will need to "shim up" the adjustment rod nut to get it tighter. Ran outa thread. I know there is some more untapped potential. I will let ya'll know how that goes.
__________________
