Power Steering Pump Upgrade
Old Mar 6, 2009 | 09:33 PM
TheTinian's Avatar
TheTinian
Ive got a 77 F250 4x4 with a 360. Ive had steering issues before, but not this bad. Ive eliminated my problem to my power steering pump. I have about 14" of lift and 40" Ground Hawgs. 91 KP Dana 60 Front, Crossover steering, and a 78-79 F350 4x4 gear box. I still have the stock power steering pump for the 360.
Ive gone through 3 pumps in the last 1.5 years. This one now is about 2 months old, and as of right now I can not turn my wheels while driving.
Im really getting tired of changing out pumps. What options do I have?? Do they make a "high performance" pump, or can another pump from any other years fit?
I was looking at the pumps from the 78, 79 year trucks. Im sure I can fab something up so it will make it work, but will I be gaining anything from it?
Old Mar 6, 2009 | 09:41 PM
75F350's Avatar
75F350
Time for a saginaw pump bubba. Gonna have to make up some brackets, but you need a decent pump. Even the 78/9 guys upgrade to the saginaw, so if you are gonna change, change it all of the way.
Old Mar 6, 2009 | 09:55 PM
TheTinian's Avatar
TheTinian
Ok. What year should I look for. Really dont know too much about the saginaw boxes/pumps.
Old Mar 6, 2009 | 10:00 PM
Jermafenser's Avatar
Jermafenser
Order a Saginaw 20-6244. I read it's made to fit 78/79s.
Old Mar 11, 2009 | 08:49 AM
TheTinian's Avatar
TheTinian
Is this the pump yall are talking about?
Power Steering Pump by Cardone - Advance Auto Parts____
Old Mar 11, 2009 | 09:20 AM
mark a.'s Avatar
mark a.
I believe so. I have one in my truck, best change I ever made to the steering.
Old Mar 11, 2009 | 09:25 AM
Jermafenser
That's the one.
Old Mar 12, 2009 | 09:01 AM
Damstr8's Avatar
Damstr8
Does the Saginaw 20-6244 use the same bracket as the old fords do? I have a 76 F250 with a 360.
Any one running the Saginaw 20-6244 a picture would be really nice.
Old Mar 12, 2009 | 09:46 AM
mark a.'s Avatar
mark a.
Yes, it does use the same ford brackets. I found a different can that fits my application better, GM made lots of different ones. These pumps can be hard to find but even if you find one thats bad all you need is the shaft out of it, get a reman, put the shaft in it & go.
Old Apr 3, 2009 | 08:14 PM
TheTinian's Avatar
TheTinian
Well I got it on. I bought it from NAPA for $80. I could have bought the cheaper one from Advanced Auto parts, but I'm done with cheap parts.
It bolted on perfect, just like it was made for the truck. Only thing I had to do was change my high pressure line. I had to buy one for a 78-79 F250. The one I had on there had a female fitting and the new pump requires and male. So about $100 upgrade, and its sure worth it so far. Drove about 10 miles today with it. Steers like a champ. Im just waiting now to see how it will do it the mud. Hopefully it wont burn up like the others.....
Old Jan 8, 2010 | 07:37 PM
bmarkline's Avatar
bmarkline
Will this work on a '78 F-150 4x4 also? I went to bolt on my stock pump today for the first time onto the 460cid I swapped in, and the pressure line comes right into the steering box, no room for a fitting and hose... its always one step forwards, two steps back with this truck.
Old Jan 9, 2010 | 03:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Saginaw P/S pumps were used on all 1975/91 Econolines.
Old Jan 9, 2010 | 10:49 AM
DaytonaTunnel's Avatar
DaytonaTunnel
Not 100% sure, but I believe some of the 80's wagons came w/a Saginaw and a 460. I have seen one, but that was a long time ago. Maybe start a new thread (Saginaw/460) and see what peeps say. I am really sure I've seen one though.
Old Jan 9, 2010 | 02:09 PM
NumberDummy
No 460's in Passenger Cars after 1978.
Saginaw P/S pump:
1972/78 Lincoln 460: Town Car & Mark IV & Mark V // 1979 Lincoln: Town Car & Mark V 400.
1972 Thunderbird 429/460 w/A/C // 1973/76 Thunderbird 460 / Some 1974/78 LTD/Mercury Marquis 400/460.
Some 1979/80 Granada/Monarch 302.
ALL 1975/91 Econolines regardless of what size the engine is / 1975/91 Econoline engines: 1975/91 = 300 I-6 & 351W/460 // 1979/91 = 302 // 1980/82 = 351M/400.
NOTE: 1965/77 Ford P/S pumps are essentially the same...have a steel reservoir and dipstick.
1978: Ford changed the P/S pump on ALL the Passenger Cars (exc w/Saginaw P/S pump), F100/350's & Bronco's. This pump has a plastic reservoir and dipstick.
The P/S pressure hoses that fit the 1965/77 Ford P/S pumps will not fit the 1978 and later Ford P/S pumps.
Most of the mounting brackets are not the same, either.
Old Dec 28, 2016 | 09:39 AM
1979Bronco400's Avatar
1979Bronco400
Final answer
So the pump listed will work, any final determination on the bracket? Asking for a 1979 Bronco 400 setup
