'78 351m has seized up from setting
Old Mar 6, 2009 | 08:47 PM
78xlt4x4's Avatar
78xlt4x4
I went to start my 78 f150 4x4 which has been in a garage and appears the engine has stuck. Should I pour marvel mystery oil in the cylinders to help loosen it up or can anyone give me a better idea where to start?
Old Mar 6, 2009 | 09:02 PM
Jermafenser's Avatar
Jermafenser
This should be in 73-79 F-series forum.
Are you sure it has seized up?
But anyway, yes, I'd start with the Marvel Mystery. Let it sit and brew for a day or two. Then take out the spark plugs, squirt oil into the cylinders and manually attempt to turn the engine (without spark plugs) a turn or two with a breaker bar.
Old Mar 7, 2009 | 07:03 AM
Lazy K's Avatar
Lazy K
Did you try to turn the engine both ways with a socket wrench on the crank pully? Especially with the plugs out?
If you did and it won`t move then 99 times out of a hundred this is caused by the rings sticking to the bores. So a penetrating fluid in thru the plug holes for a day or two and with plugs out then try again with the socket wrench. Good luck.
BlueOvalDismantlers
18
Oct 22, 2024 10:39 AM
ford_0004
Mar 15, 2015 09:57 AM
twinzilla
16
Jan 14, 2015 07:30 PM
Tsoptich
Nov 1, 2011 09:12 PM
78f3504x4
15
Jul 2, 2011 06:29 AM
