brake light problem
Old Mar 5, 2009 | 11:45 PM
drbigknuckles's Avatar
drbigknuckles
brake light problem
ok guys got another head scratcher. my brake light seams to come on alot. i know when you hit the pedal like 3-4 times it will drop psi and it will come on. but if i pull into parking spot hit the brake and back up and hit the brake the light comes on. what could be wrong or is it nothing to get in a bind about. the brakes seam to still work fine when this happens. i just dont rember seeing this before....
Old Mar 5, 2009 | 11:50 PM
onefarmer's Avatar
onefarmer
Let's start with the basics. Did you check the fluid level?
Old Mar 5, 2009 | 11:51 PM
flamebuster's Avatar
flamebuster
what type of rig are you driving? gas or diesel? is your fluid resevoir low? how far down does your pedal travel? or better yet how far from the floor is it? If it is close to the floor near full pedal stroke you may need to manually adjust the rear brakes tighter, to much travel.
Old Mar 5, 2009 | 11:56 PM
drbigknuckles
yep full to the line..
Old Mar 5, 2009 | 11:58 PM
drbigknuckles
diesel. fluid is toped off. the pedal is about 3 inches off the floor it hooks the brakes soon as u push the pedal so i dont think its a seal issue.
Old Mar 6, 2009 | 03:52 AM
Cuda_jim's Avatar
Cuda_jim
The brake light will come on if the vacuum drops off to a certain level. IIRC less than 7 in-Hg. You should normally have 17-21 in-Hg with the engine running. KOER
You may either have a vacuum leak or the vacuum pump is getting weak or the belt is slipping on the vacuum pump.
You can put a vacuum gauge on it and see if it's dropping too low after a couple brake pedal applications. KOER
Also check it with the engine off. Start it up and run the engine for 10-20 seconds, turn it off, the vacuum gauge should not drop more than 1 in-Hg in 1 minute. If it does, you have a vacuum leak.
Old Mar 6, 2009 | 04:12 AM
drbigknuckles
where is the vacuum pump located on the water pump belt?
Old Mar 6, 2009 | 04:16 AM
Cuda_jim's Avatar
Cuda_jim
I only have one belt...pretty sure you do to. The pump is on the driver side....can't miss it.
Old Mar 6, 2009 | 05:55 AM
MADVAN's Avatar
MADVAN
I will add vac switch to the list.
If you vac test good replace the switch.
Its known to go bad.
Bill
Old Mar 7, 2009 | 06:37 AM
DRRXR's Avatar
DRRXR
There are cases where the vacuum pump bearings start sliding in the race way on 96 models and crapping the vacuum pump out. So if there is intermittent issues this could be related to your problem. Mine trashed out on me at around 75k. I was hauling at 65 m/hr could not hardly stop her missed taking down some median signs by inches. Had to clean my shorts. Anyhow check your belt for wear and take the tention off of it and test the vacuum pump bearing by simply rotating it by hand. Feeling for rough spots and catches.
Old Mar 8, 2009 | 11:32 PM
drbigknuckles
i put a new belt on this weekend and turned the pump by hand when the belt was off. seamed to turn fine no hard spots. maby its the vaccume switch going bad?
Old Mar 9, 2009 | 01:18 PM
allisonmo2's Avatar
allisonmo2
i'm gonna chime in too since i have a similar problem. my light comes on now all the time too. 97 diesel. fluid full. usually when i am backing up. sometimes when it happens my pedal is rock hard though and barely travels 1/2" down, and the truck won't stop at all. very unnerving. but if i let off the light will go out and my brakes are fine. only happens at low speedds like pulling out from a parking spot. 99% of the time my brakes are fine, but that 1% scares me! my level was a little low last week. mabye 3/4" from the full mark so i added fluid to top it off, and my first thought was an air bubble in there somewhere but i thought that would give me a soft pedal not a super firm one.
Old Mar 9, 2009 | 04:51 PM
tjbeggs's Avatar
tjbeggs
You have vacuum issues as well. Check everything mentioned above
Old Mar 9, 2009 | 05:26 PM
rungunner's Avatar
rungunner
Vacumm problem
I have been trying to solve the same problem since last summer. I am convinced it is a vacumm leak somewhere.
