smoking issues timing issues
Old Mar 7, 2009 | 10:23 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
One other thing...you said there was a "clicking" sound...that's probably your lifters not having enough pressure to pump them up.
As long as it wasn't a "clacking" sound, you should be OK. Depending on the condition of your oil and the junk that was in it, you might want to do a cheap oil and filter change, warm it up for a few minutes each day for about a week (varying your RPMS but not too high), and then do a GOOD oil and filter change to make sure that any residue gets flushed out.
Old Mar 8, 2009 | 08:49 AM
btorear's Avatar
btorear
I'm pretty sure it was just a clicking sound was a couple days ago and when i heard it i shut her down immediately. What would a "clacking" sound indicate?
Old Mar 8, 2009 | 08:51 AM
btorear's Avatar
btorear
the sound reminded me of when i used to run cheap gas in my '89 ford ranger when i was younger.
Old Mar 8, 2009 | 09:36 AM
Bowtie_Schmowtie
Clacking usually indicates a problem with your rod bearings.
Since you shut it down immediately when you heard the noise, I think you'll be OK.
After you change the oil and filter, disconnect the coil-to-distributor wire and crank the engine over until you get some oil pressure built up. Then reconnect the wire and start as normal. This way you'll have some good oil circulated to your bearings before they are put under load.
Old Mar 8, 2009 | 09:45 AM
btorear's Avatar
btorear
ok. will do. Thanks so much for the advice. you've been a big help
Old Mar 9, 2009 | 01:36 AM
classicfordman's Avatar
classicfordman
when i change my oil i always use a quart of lucas oil in my engine to make sure to keep plenty of oil on my berings, to prevent a dry start..
Old Mar 9, 2009 | 06:21 AM
btorear's Avatar
btorear
I've heard that products like that could gum up the engine with sludge. Do you know if this is true? Someone told me to put in STP oil treatment or maybe something called Rislone too.
Old Mar 9, 2009 | 06:24 AM
btorear's Avatar
btorear
oh by the way there appears to be no damage done to the engine. but the timing is off. the housing that the distributor cap sits on wiggles about 1/4 inch either way, i may use some epoxy to hold it still so i can set the timing this evening. she was backfiring yesterday after the oil change and start up.
Old Mar 9, 2009 | 09:18 AM
Jermafenser's Avatar
Jermafenser
I wouldn't do that.
What about Additives?
Old Mar 9, 2009 | 09:19 AM
Jermafenser
Why the hell would you want to put epoxy on it?! Find why it's loose and tighten it down the correct way. You may have to change the timing later on...but you can't, because you epoxied it! Do you really want to do that?
Old Mar 9, 2009 | 09:59 AM
btorear's Avatar
btorear
i'm not going to epoy the distributor to the block. I'm going to epoxy the housing that the distributor cap clamps to, to the distributor body.
Old Mar 9, 2009 | 10:00 AM
btorear's Avatar
btorear
it's held to the distributor body with clamps, and they aren't holding it tight
Old Mar 9, 2009 | 11:52 AM
  #28
Jermafenser
Some looseness is OK; if it's really loose, buy a new distributor cap adapter for $5-10.
Gluing the cap to the body will have to be broken free when it's time to replace the distributor...never a good idea.
69_Eliminator
Modular V10 (6.8l)
22
May 25, 2015 10:12 AM
Forddiesel17
22
Feb 27, 2015 08:56 AM
acf6
Oct 12, 2013 11:01 AM
acarter92
Sep 9, 2013 05:05 PM
IDIDieselJohn
Aug 11, 2013 12:19 AM
