1999 V10 Oil Smoking
Hello all, I just bought a very used 1999 F-250 Super Duty V10 with 173K on the clock. The previous owner told me that it oil smokes when first started for the day and goes away, which is true.
I brought it home Monday evening, Tuesday afternoon I started it at lunch time and it smoked quite a bit, I only let it run for about 2 minutes. That evening when I came home from work I started it up and it smoked so I thought it was just valve stem seals and it would clear up. I revved it up a few times to about 2000 RPM and it would put out a lot of smoke, I let it idle for about another 10 minutes and it was still smoking.
I haven't driven it on the street again since I haven't gotten license for it.
I read that the V10s PCV system can cause smoking, especially if there is a problem with the PCV valve. I pulled the PCV valve yesterday when it was running and it still smoked just as bad. I turned off the engine and inspected the PCV valve. It looked like it has recently been replaced and when I shook it the inside rattled and wasn't gummed up or sticking at all. Is there anything else I need to check in the PCV system?
I also read where some people said their V10 smoked more with synthetic oil. I doubt someone would have put synthetic in this old work truck, but I guess anything is possible. I am going to change the oil and put conventional in it and see if that makes any difference.
I read where someone said to put Sea Foam in the engine oil because it might have a stuck ring and drive it for a few hundred miles.
I was thinking valve stem seals, but seems odd that I ran it for 10-15 minutes yesterday and the oil smoking never went away. Also can anyone tell me why it smokes like crazy at idle when cold, but will only smoke for about the first 1/4 mile when driving it and it never smokes again until it sits.
Please advise on what I can do or inspect before I pull the heads and do the valve seals or find a junkyard engine for it.
Thanks!
Thanks!
Thanks for the reply!
When we picked it up the other night it smoked for about the first 1/4 to 1/2 mile and didn't smoke the rest of the way home on a 45 minute drive. My brother was following behind and said it only smoked that first little bit. I need to get tags and insurance on it so I can drive it around more this weekend and see what it does.
Any thoughts or things to check next?
That is more or less so what I'm leaning towards, just need to figure out what the next step is to find out where it's getting into the cylinders from. I just got tags and insurance on it today, I'm going to drive it around a bit this weekend and see if I can figure anything else out.
The old lady and I took the truck out tonight. It smoked an embarrassing amount for the first 1/2 to 3/4 mile we drove it and then quit smoking shortly thereafter. We drove it for about 10-15 mins around town, stopped at a gas station to check out the beer selection, came back out, fired it up and no smoke whatsoever. We then cruised around town for about 20 more mins, stopped at Home Depot for about 20 mins, went back out, fired it up and no smoke. Drove it down the highway, stopped at another store for about 20 mins, came back out fired it up, no smoke.
This is only a guess but I'm thinking you possibly have a very slow antifreeze leak possibly in the lower intake manifold.... I've dealt with completely shot intake manifold gaskets, blown Head gaskets and cracked heads with smoke like this all the time but the symptoms you're describing I haven't experienced. Like I said it's only my best guess.
Also are these earlier V10s known for having any intake problems or anything that I should zero in on while inspecting?
thanks for your help and everyone else that his commented so far
I called one of the local parts houses looking for intake gaskets. He said he needed the manufacture date. My truck doesn't have a sticker on the door or cab, possibly from an earlier accident repair. The parts guy told me to call Ford, give them the last 8 of my VIN and they can tell me the build date. I called Ford and the parts guy there said they can only do that on '05 and newer, but he said mine would take the later gasket set since it's a '99 it would be built after July '98. Does anyone know if that is correct so I can make sure I get the correct gaskets?
