Cruise control light
Old Mar 5, 2009 | 11:47 AM
bronco252's Avatar
bronco252
I have a 2002 SD and my cruise control is working but my light doesn't come on. I'm assuming that the bulb or led or whatever's in there is bad. My question is it a changeable lamp or do I have to tear the dash apart, unsolder lamp, resolder lamp and put everthing back together. Or can you reach the lamp from under the dash and remove it by hand? I really don't want to have to tear into the dash just to replace a lamp I don't need but I'm the type that doesn't like stuff that's not working properly. Any help would be greatly appreciated...
Old Mar 5, 2009 | 11:52 AM
Supercab's Avatar
Supercab
Wink
I would say if you've got an '02 that you have the light, and I'll bet its just burned out, I have no idea as to how to replace it, may be someone else knows?
Old Mar 5, 2009 | 01:16 PM
triskit16's Avatar
triskit16
I remember someone saying something about the 99 PCMs didnt have the ability to light that light even though the dash had the light. Unless you have a 99 PCM in there for some reason I think the light is just blown. Im not too sure but I dont think you can reach it from underneath or that you would want to if you could. Ive been under there and theres no telling what you would be pullling. As long as its working I would just say the hell with the lamp. Not worth all that trouble IMO.
Old Mar 5, 2009 | 01:53 PM
aldridgec's Avatar
aldridgec
It's hard to say if it's a bulb. It's about an hours worth of work to change a bulb in the cluster. It should be a bulb though.
Old Mar 5, 2009 | 02:01 PM
HKusp's Avatar
HKusp
If you pull out the cluster, it's a bulb. It's the same bulb that the cab clearance lights use.
Old Mar 6, 2009 | 06:10 AM
bronco252's Avatar
bronco252
Thanks everyone for your input...I think I'll just wait until I have some extra time on a rainy day to change it out...
Old Mar 6, 2009 | 06:13 AM
bobmiers's Avatar
bobmiers
In my 2000 all of the bulbs are the same. About a year ago, I noticed that the WaterInFuel light didn't past the start up test. Took out the cluster to reach the back and tested the bulb -- it was OK. So I cleaned the printed circuit pads for that bulb and reinstalled. It work. So, guess what, I cleaned all of the other pads as well... a gentle rub with a pencil eraser is all that is necessary. FYI I couldn't find replacement bulbs at the local AZ, Ck, or NAPA. The dealership had them at just under $5 each....
brokersteve
Jan 16, 2017 11:39 AM
A/Ox4
2009 - 2014 F150
Dec 27, 2016 08:53 PM
greystreak92
1978 - 1996 Big Bronco
17
Mar 27, 2012 07:53 PM
Thudpucker
1997 - 2003 F150
Aug 30, 2009 10:29 AM
wilhite43
Mar 17, 2008 05:08 PM
