Heat induction tsb
Old Mar 5, 2009 | 11:38 AM
6litrefan's Avatar
6litrefan
Heat induction tsb
My truck is a 2007 and was built in May of 2006 does or should my truck have the newest heat induction re-flash on it???
Thanks guys!
Ryan
Old Mar 5, 2009 | 03:49 PM
6LPSD's Avatar
6LPSD
check this link out man this should give you all the info you need about the inductive heat flash update for the pcm/injectors.
Improved 6.0L Power Stroke
Injector Spool Valve Sticking Reflash:
Inductive Heating Strategy February 7, 2007
http://turbodieselforums.com/diesel_2.pdf
Old Mar 5, 2009 | 03:50 PM
6LPSD's Avatar
6LPSD
it heats the injectors where the oil is in them to make the engine start and idle better upon initial cold start up if you are having rough idling and hard starting issues when cold.
ChrisAU
Feb 12, 2013 07:54 AM
a-rod
Nov 12, 2007 09:29 PM
Hunter40
Feb 28, 2007 05:14 PM
Ryan50hrl
Paint & Bodywork
Jan 20, 2002 03:04 PM
Ryan50hrl
Dec 6, 2001 11:13 AM
