F250 Electrical Problem!!
Old Mar 5, 2009 | 08:18 AM
dlbcraftsman's Avatar
dlbcraftsman
This is driving me nuts!!!!!! Truck starts and runs fine, volt guage is showing it is charging, all guages are functioning. Now for the fun,,,, Man. trans,,,,Shift into any gear, and start moving and the guages all peg out, volt guage drops, speedo jumps all over the place,, come to a stop, and everything returns to normal.?? Use fan blower, wipers,lights, volt guage drops to 8-9v. Turn everything off returns to 13-14v. Whats up with this??? Been under truck, dont find anything rubbing or loose. Grabbed every wire harness looking for a short to frame, but have found nothing. Any Ideas??? I'm losing my mind
Old Mar 5, 2009 | 10:57 AM
maneyup's Avatar
maneyup
well i cant tell you much just yet for starters what year does your truck happen to be? does it do this with engine idling clutch in? does it do this with engine idling clutch in trans in a gear? or is it just when you start moving and the engine rpms change?
Old Mar 5, 2009 | 11:12 AM
starmilt's Avatar
starmilt
Everytime there is a bunch of stuff acting up I look for a bad ground somewhere.
Old Mar 7, 2009 | 12:19 AM
ford trans tech's Avatar
ford trans tech
add a ground strap from the engine to the cab
and another one from the engine to the right fender apron metal plate that the voltage regulator is mounted to
Old Mar 7, 2009 | 05:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It does sound like a ground is very likely the culprit.
Battery main grounds go to the engine.
Several smaller grounds and ground straps then pass the ground to the frame, cab, fenders, mounting plate for the regulator and bed.
jraquel
1997 - 2003 F150
Aug 12, 2012 11:35 PM
fixitman1310
Nov 7, 2009 02:39 PM
kamloops
1997 - 2003 F150
Apr 26, 2008 11:35 AM
32MTXSHO
Modular V8 (4.6L, 5.4L)
Dec 6, 2007 09:37 AM
Striker711
16
Nov 22, 2006 12:21 AM
