Here's a new one...
Old Mar 5, 2009 | 12:25 AM
88-150's Avatar
88-150
Here's a new one...
In my quest of all things Fordly, something else has decided to appear from the bowls of my engine bay(besides the sand in the power steering thing)It started a week ago, stopped and is back. I'll go to start it, the starter will attempt to turn the engine, then spin freely. I usualy smell gas afterwards. This'll happen 4 or 5 times before it does actualy start. I'm thinking it's the starter relay but I want to be sure before I fork over $50 to Advance Auto for a new starter.
-Matt
Old Mar 5, 2009 | 12:41 AM
kermmydog's Avatar
kermmydog
How about a bad Bendix spring or Starter drive which ever you wish to call it, on the starter. Sounds like the sprag is shot. From what you describe you can buy the drive & install it or buy a starter. Probably the starter would be the way to go IMO.
Old Mar 5, 2009 | 01:20 AM
88-150's Avatar
88-150
ok - i just wanted to be sure before i started replacing things it might be instead of what it is. What causes it? Just age or what..
Old Mar 5, 2009 | 06:55 AM
uncle.stosh's Avatar
uncle.stosh
Before buying any parts have them check it out for you if you can't do it your self.
They have a machine that they hook it up to for free.
Old Mar 5, 2009 | 07:13 AM
lew52's Avatar
lew52
I agree with the starter drive...It sounds like the starter is working but the drive gear wont stay ingaged to the flywheel..Lew
Old Mar 5, 2009 | 08:21 AM
70 Maverick's Avatar
70 Maverick
sounds like the bendix is kicking back in,too early.could be from age,or a bad/corroded connection.take it off,and have it tested.your local autozone/advance can put it on their tester.eventually it's going to leave you sitting.
Old Mar 5, 2009 | 09:21 AM
88-150's Avatar
88-150
yeah, that's what i'm affraid of. I was trying to narrow it down to either the starter relay or something in the carburator since I was also smelling gas, leaning more towards the relay. Parts should be made to last forever lol.
Old Mar 5, 2009 | 12:11 PM
Franklin2's Avatar
Franklin2
I am not sure they can test the bendix at the store. It has a one-way clutch bearing in it, that lets the starter turn the flywheel, but will not let the flywheel turn the starter and burn it up if someone holds onto the keyswitch too long. When these go bad, they get intermittent, and will not let the starter drive the flywheel, even though the gear is engaged in the teeth.
Old Mar 5, 2009 | 12:38 PM
lew52's Avatar
lew52
Ya i dout they will be able to tell if the bendix is bad at the auto store... That would probabley have to be removed to inspect it...There just going to run a hot wire to it the same way we would with a battarey & jumper cables..But it sounds like hes going to replace the relay..Lew
Old Mar 5, 2009 | 02:28 PM
82-100's Avatar
82-100
i dont know about where you live but here we have several electronics repair shops that work on and rebuild starters and altenators. if you can find one of these shops it will save you some dough. i know i had them rebuild my alt. and was about 1/3 the price of a new one and you will still have your oem part. just a thought?
Old Mar 5, 2009 | 06:10 PM
88-150's Avatar
88-150
I dunno if Sioux City has any of those places, but it's worth a look since I know they have 'em in my hometown out west.
lemonshindig
May 22, 2014 10:18 AM
thumper869
Oct 27, 2009 01:17 AM
1985f350
Sep 20, 2006 07:16 AM
mtodd101
Mar 17, 2004 04:58 PM
mkbernier
Apr 5, 2002 11:50 AM
