Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Tuff Shed
Old Mar 4, 2009 | 08:22 PM
sltrrco's Avatar
sltrrco
Tuff Shed
I am needing the plans or mesurments for a 8' x 16' Gambrel Roof shed. If any body has them It would be great. I have look on the net and at public library. But no hope. All I need is the angle of the roof trusses.
Old Mar 4, 2009 | 11:46 PM
Chaosracing's Avatar
Chaosracing
There is alot of vairable for figuring out the angles, there is no set value. But I just did a quick sketch on CAD to come up with a 71 degree for the first angle and 19 or 26 degree for the second, both coming off zero degree and that being east on the compass. To make the lengths look even and with a 6" overhang, you will be using the 26 degree angle. This is all assuming the peak of your shed to be at 4' above the highest horizontal point on your frame. This will give each leg an approximat 3'-2 to 3'-5" length. The angle change will be 3' straight up (90 degrees or north) from the lowest point of the roof edge.
If no overhanging eave, then use the 19 degree angle for the upper part of the truss, still changing angles at 3' above the highest horizontal point on your frame.
I have no clue how to post a drawing to show this, so I hope my explanation helped. If you are going higher or lower than the 4' let me know and I can help you out. Also let me know if there is going to be an overhang. But for an 8' wide structure, I think what I chose would be the best for looks.
Old Mar 5, 2009 | 01:30 AM
ford2go's Avatar
ford2go
I've got a book called the "The Ultimate Guide to Barns Sheds and Outbuildings " ( hey, why be modest ) by John Wagner and Clayton DeKorne.
I really haven't used it, but I just looked up roofs. It has a few pages of guidelines for designing gambrel roofs.
The same author(s) had another book that was more shed oriented. That one was in our local library. I found this one on amazon. You might try searching using the author's names.
Old Mar 10, 2009 | 07:42 PM
LeadDoggy's Avatar
LeadDoggy
Here's a few shots of my 16' X 24' barn. Don't remember the angles but you could layout some 2x4s on the ground and make a prototype truss.
Old Mar 10, 2009 | 09:05 PM
sltrrco's Avatar
sltrrco
I got some plans of of e-bay for a 8x10 shed I am going to used them as a diagram. I will post pictures when the add. is done.
Scotty's 52 F3
17
Oct 24, 2015 09:41 AM
Fifty4F100
Nov 27, 2013 11:52 AM
C. Lee Colbert
New Jersey Chapter
Jul 7, 2006 11:16 AM
jake00
22
May 30, 2006 10:26 PM
