Express Bed/Box Stake Pockets Needed
Old Oct 14, 2015 | 05:23 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I know this is a long shot but I have to ask. Does anybody have a ratty old Express Box that might have decent front stake pockets?
I found a really nice straight bed that actually has just surface rust and even has most of the wood still intact. EXCEPT.....the front stake pockets. Bottoms are gone. Shed roof dripped right on them for 40 years. Drain holes plugged up and you know the rest.
I've looked at plenty of rusted out beds that had good stake pockets. Anybody have one they would be willing to take the stake pockets off of?
I could get away with just the lower half. I don't think I could fab one.
Old Oct 14, 2015 | 05:39 PM
Cougar54's Avatar
Cougar54
They reproduce them for the F1. Can't you just get one of those and just use the lower half?
Old Oct 14, 2015 | 05:54 PM
49fordv8f4's Avatar
49fordv8f4
I have a '48-'52 express bed that is pretty rough. I will look tomorrow to see if the pockets are any good.
Old Oct 14, 2015 | 06:03 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Doug, I don't think any part of the F-1 front or rear pockets can be made to work on the express beds. I may be wrong, but don't think so.
My understanding is that the entire F-2/3 beds shared nothing in common with the half-tons, except perhaps the chains.
Old Oct 14, 2015 | 06:07 PM
fordf348's Avatar
fordf348
F-1 pockets are totally different than F-2-3
Old Oct 14, 2015 | 06:51 PM
Scotty's 52 F3
I saw a thread somewhere that a guy tried to make an F1 stake pocket work and he couldn't do it. Too different.
That would be great if you had one Mark. Thank you for checking.
Old Oct 14, 2015 | 10:01 PM
jmadsen's Avatar
jmadsen
Chains are way different too.
Old Oct 14, 2015 | 10:09 PM
harleymsn's Avatar
harleymsn
Would the 53+ F250 pockets work?
Old Oct 14, 2015 | 10:13 PM
Scotty's 52 F3
I got lucky with the chains. Still got the originals.
I really like having the F3 because it's different. You just don't see them compared to the F1's. Finding parts for them SUCKS!!!
Seems like everybody that wanted or needed F2's and F3's lived in the rust belt. I can find TONS of F1 parts here in AZ. Forget about the bigger trucks.
Old Oct 14, 2015 | 10:15 PM
Scotty's 52 F3
I don't know about the 53 up beds? Hopefully someone will chime in.
Old Oct 14, 2015 | 10:47 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
There was a thread a while back where a member was looking for suggestions of parts to repop in fiberglass. Perfect candidate. Stu
Old Oct 14, 2015 | 11:18 PM
jmadsen's Avatar
jmadsen
Here is the one thread and i see that you already suggested stake pockets.
https://www.ford-trucks.com/forums/1...***-parts.html
I agree. Fiberglass could be glued right to the bed sides.
Here is the other thread.
https://www.ford-trucks.com/forums/1...-im-ready.html
Ive got a couple parts f2 f3s and most of the stakepockets are hammered. I planned on doing the same thing swiping a good one here or there to make two good complete express beds.
I need to look closer at the rear stakepockets but i think those could be used on the front as well?
I could probably get one clean one to send in as a template if there was demand i bet he would make them.
Old Oct 15, 2015 | 12:51 AM
52 Merc's Avatar
52 Merc
48-52 F2/3 beds use a curvy stake pocket like the 48-50 F1's, but are dimentionally larger all the way around. The 53 and later long beds have the square pockets like the 51-up half tons, so there's no interchange possibility.
Old Oct 15, 2015 | 11:27 AM
49fordv8f4's Avatar
49fordv8f4
Here are a couple of photos of the front stake pockets. You will notice that the passenger side has a dime sized hole showing thru at the bottom corner. I think it would be an easy fix as the pocket seems solid otherwise.
This is the passenger side, notice the hole.
This is the drivers side.
If you are interested I will cut the corners off of the bed and you can remove the pocket from it. Does $20.00 each plus shipping sound fair?
Old Oct 15, 2015 | 12:12 PM
Scotty's 52 F3
Those look like an easy fix. Mine front ones are completely gone at the bottom.
$20 each plus shipping is very fair. THANK YOU! I will PM you some info.
