White faced lgauges on 85' f-150
Hey guys just need some help. I want to paint my black gauges white. has anyone done this before? I have a 1985 f-150. also if anyone has done this does the light that shows the guages at night sit in front or behind the gauges? Thanks for any answers to my questions.
I don't know anyone who's ever painted them, it would have to be a pain though. The face is back lit and the portions you see lit up are translucent. You would have to be very careful and not put paint over the numbers or the little ticks. I believe NR has the older faces still, and you can probably talk to NuImage to see if they have any laying around. The swap would be much easier.
https://www.ford-trucks.com/forums/6...d-cluster.html
I did mine a few years ago. I took everything apart and just sprayed everything with an off white, then repainted all the lines, numbers, and needles with a brush and model paint. Takes a little patience and a steady hand, but well worth it.
BTW, the light shines from behind the gauges. Having the white faces helps with the visibility greatly. Using a brighter bulb would make it even better. I plan on replacing my bulbs with LEDs since I don't use the dimmer anyways. I have also been suggested to paint the inner housing (where the gauges sit in) with a reflective paint to aid in the light projecting onto the gauge faces. Good luck if you decide to pursue this.
