Stock and Modded Boost Numbers...
Old Mar 3, 2009 | 11:58 PM
Bigfwt04's Avatar
Bigfwt04
I had a local Ford mechanic that works at the dealership on 7.3L and 6.0L only tell me that stock boost for a 7.3L is 13-15psi and even chipped, intake and exhaust he has never seen above about 21psi. Does that sounds right? I was under the impression that stock was around 18-21psi and modded could be up to 25-27psi. What numbers on the 38R and Van turbo? Just a thought, thanks guys.
Old Mar 4, 2009 | 12:03 AM
liftedgrocerygetter's Avatar
liftedgrocerygetter
That guy was lying out his *** too you..... I only have very minimal stuff on my truck and I can hit 24-25. The big boys are hitting over 30.
Old Mar 4, 2009 | 12:05 AM
Bigfwt04's Avatar
Bigfwt04
Thats more what I thought I had read over and over on here, but I thought maybe I was wrong. I will have Brandon set him straight when he comes out next week Thanks for the help Cris
Old Mar 4, 2009 | 12:06 AM
DCSpecial's Avatar
DCSpecial
Stock is more like 17psi.
Chipped, intake and exhaust I can easily hit 28 psi....maybe more, I don't really look at it (and it's been over 5 months since I've driven my 01 )
Old Mar 4, 2009 | 12:10 AM
Bigfwt04's Avatar
Bigfwt04
Where you been boss? Are you not a sponsor anymore? I haven't seen you around helping all use suspension newbies
Old Mar 4, 2009 | 12:18 AM
DCSpecial's Avatar
DCSpecial
Been around, still posting....although more so in the SD forum lately it seems.
And you'd be correct, just a regular member now.
Old Mar 4, 2009 | 12:26 AM
robs01f250's Avatar
robs01f250
That mechanic is freaken crazy i can hit between 31 and 33 with the wastegate unplugged and about 29 with the wastegate plugged in
Old Mar 4, 2009 | 07:42 AM
bigbubba87's Avatar
bigbubba87
if i really stand in mine it has a bigger turbo,a ts chip and 6637 mod and i can burry the guage on 40psi
Old Mar 4, 2009 | 08:03 AM
jdecker88's Avatar
jdecker88
There is no way on stock sticks plain TS chip and a Garrett turbo need to check your boost gauge.
I see 25 on mine but I haven't really payed attention when I am WOT.
Old Mar 4, 2009 | 09:44 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
They guy is nuts, with the exception if you don't have a boost fooler device ?
In stock form if the MAP sees anything more than 17psi, it drops boost and sets overboost SES.
With a regulator or something, you will get more. I get over 20# with no issue. Towing up a grade, I can easily get over 30#
ZooDad
Old Mar 4, 2009 | 10:06 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I was getting 30+, stock turbo and sticks. With DP-TUNER of course. Now with the TN BB and SS Stage II's, the last time I looked I was at 33#, I think I can do 35#. I watch the egt gauge more.
Old Mar 4, 2009 | 11:49 AM
bigbubba87's Avatar
bigbubba87
unless my guage is wrong or something it will go all the way to 40. i do now know what all has been done to the motor all i know is it has a garrett ball bearing turbo boost anhilator and a ts chip.
Old Mar 4, 2009 | 12:04 PM
miller_feed
What kind of boost do you show going down the highway?
Old Mar 4, 2009 | 03:06 PM
Ziggy.'s Avatar
Ziggy.
I've only got a wicked wheel in my stock turbo, with the water meth it'll hit 32-33# but I wont let it go higher with the meth b/c I havent done headstuds yet and I dont want to take a chance. And I leave the WG line on for the same reason
Old Mar 4, 2009 | 05:07 PM
crum71's Avatar
crum71
1/8 mile Oval Track
The most Ive hit is 28 on mine
