Noise when in 4x4
Old Mar 3, 2009 | 08:17 PM
afonda's Avatar
afonda
Noise when in 4x4
There is a humming or whuring noise coming from the front end when I go into 4x4. It is intermittent and seems more pronounced when under torque.
No vibration.
ESOF not working. Using manual lock.
Old Mar 3, 2009 | 08:30 PM
Ponyboychris's Avatar
Ponyboychris
Try this procedure.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
It helped when my OEM hubs were sticking and may help with your issue. I didn't have the humming sound though. Just a thought.
Old Mar 4, 2009 | 09:33 AM
afonda's Avatar
afonda
I think when I do get into that I'm just going to do the whole smash... uJoints, seals, bearings... everything I can get at while I'm in there and its torn down.
I dont want to go back in over and over...
Old Mar 4, 2009 | 01:58 PM
triskit16's Avatar
triskit16
I had a slight humming in mine a while back and it ended up being the knuckle seal that failed. They had put the thrust washer back in the wrong place and it ate the seal up nicely. That with no yellow o-ring and ESOF definitely didnt work!
creedua
Feb 19, 2015 09:49 AM
superglide04
Mar 18, 2014 09:02 PM
rmckenna
Jan 19, 2010 07:00 PM
Will_01_GT
1978 - 1996 Big Bronco
Dec 21, 2004 03:57 PM
sk1332
Mar 1, 2004 11:03 PM
