Difference in ZF-5 transmissions
Old Mar 3, 2009 | 06:05 PM
Mike8623's Avatar
Mike8623
OK guys, need a tranny expert here...........Exactly what is the difference between the SD42 and SD47 transmissions.............I guess one was made for early on and one for 95 and later..........but what was the differences in them..............
Old Mar 3, 2009 | 06:22 PM
plowhand's Avatar
plowhand
Playing in the Dirt
The SD47 will take more torque than the SD42. I was told by a tranny guy that the SD42 was built for gas engines and then used on some diesels with low torque.
Old Mar 3, 2009 | 07:15 PM
Diesel_Dirk's Avatar
Diesel_Dirk
<HR align=left width=600> <TABLE cellSpacing=1 cellPadding=5 width=600 border=0><TBODY><TR><TD vAlign=top width=100> </TD><TD vAlign=top width=135>S5-42, ZF
</TD><TD vAlign=top>ZF S5-42 – 5 speed manual transmission has an aluminum alloy main gear case and tail housing with the bell housing integral to the case.
The ZF S5-42 is built in both a 2 wheel drive and 4 wheel drive version with gas and diesel designs
ZF first introduced the S5-42 in 1987 and was used in the Ford F250, F350, F450 and Super Duty trucks until 1994.
All gears on the S5-42 are fully synchronized with an input torque rating of 420 ft-lb
Standard gear ratios on the ZF S5-42:
<TABLE cellPadding=0><TBODY><TR><TD><TABLE cellPadding=0 width=166><TBODY><TR><TH scope=col colSpan=2>Close Ratio </TH></TR><TR><TH scope=row width=85>
1st Gear:
</TH><TD width=73>4.14 </TD></TR><TR><TH scope=row>
2nd Gear:
</TH><TD width=73>2.37 </TD></TR><TR><TH scope=row>
3rd Gear:
</TH><TD width=73>1.42 </TD></TR><TR><TH scope=row>
4th Gear:
</TH><TD width=73>1.00 </TD></TR><TR><TH scope=row>
5th Gear:
</TH><TD width=73>0.77 </TD></TR><TR><TH scope=row>
Rev Gear:
</TH><TD width=73>3.79 </TD></TR></TBODY></TABLE></TD><TD><TABLE cellPadding=0 width=166><TBODY><TR><TH scope=col colSpan=2>Wide Ratio</TH></TR><TR><TH scope=row width=85>
1st Gear:
</TH><TD width=73>5.72 </TD></TR><TR><TH scope=row width=85>
2nd Gear:
</TH><TD width=73>2.94 </TD></TR><TR><TH scope=row width=85>
3rd Gear:
</TH><TD width=73>1.61 </TD></TR><TR><TH scope=row width=85>
4th Gear:
</TH><TD width=73>1.00 </TD></TR><TR><TH scope=row width=85>
5th Gear:
</TH><TD width=73>0.76 </TD></TR><TR><TH scope=row width=85>
Rev Gear:
</TH><TD width=73>5.24 </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>The ZF S5-42 main case cast number is “1307”
</TD></TR><TR><TD vAlign=top width=100> </TD><TD vAlign=top width=135> </TD><TD class=style11 vAlign=top><HR></TD></TR><TR><TD vAlign=top width=100> </TD><TD vAlign=top width=135>S5-42 4x4, ZF
1st Gear:
2nd Gear:
3rd Gear:
4th Gear:
5th Gear:
Rev Gear:
1st Gear:
2nd Gear:
3rd Gear:
4th Gear:
5th Gear:
Rev Gear:
</TD></TR><TR><TD vAlign=top width=100> </TD><TD vAlign=top width=135> </TD><TD class=style11 vAlign=top><HR></TD></TR><TR><TD vAlign=top width=100> </TD><TD vAlign=top width=135>S5-47 4x4, ZF
</TD><TD vAlign=top>ZF S5-47 – 5 speed manual transmission has an aluminum alloy main gear case and tail housing with the bell housing integral to the case.
The ZF S5-47 is built in both a 2 wheel drive and 4 wheel drive version with gas and diesel designs
ZF introduced the S5-47 in 1995 and was used in the Ford F250, F350, F450 and Super Duty trucks.
All gears on the S5-47 are fully synchronized with an input torque rating of 470 ft-lb
Standard gear ratios on the ZF S5-47:
<TABLE cellPadding=0><TBODY><TR><TD><TABLE cellPadding=0 width=166><TBODY><TR><TH scope=col colSpan=2>Close Ratio - 7.3L Diesel </TH></TR><TR><TH scope=row width=85>
1st Gear:
</TH><TD width=73>5.08 </TD></TR><TR><TH scope=row>
2nd Gear:
</TH><TD>2.60 </TD></TR><TR><TH scope=row>
3rd Gear:
</TH><TD>1.53 </TD></TR><TR><TH scope=row>
4th Gear:
</TH><TD>1.00 </TD></TR><TR><TH scope=row>
5th Gear:
</TH><TD>0.77 </TD></TR><TR><TH scope=row>
Rev Gear:
</TH><TD>4.66 </TD></TR></TBODY></TABLE></TD><TD><TABLE cellPadding=0 width=166><TBODY><TR><TH scope=col colSpan=2>Wide Ratio</TH></TR><TR><TH scope=row width=85>
1st Gear:
2nd Gear:
3rd Gear:
4th Gear:
5th Gear:
Rev Gear:
</TH><TD width=73>5.24 </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>The ZF S5-47 main case cast number is “1317”
Old Mar 3, 2009 | 07:23 PM
Mike8623's Avatar
Mike8623
I appreciate all the quick info........so it appears all that is different is the input torque and the the "close ratio"............just what is the "close ratio"
and what is the wide ratio?
Old Mar 3, 2009 | 07:39 PM
Diesel_Dirk
Close ratio has the gears spaced further apart (numerically, not physically)than the wide ratio. In other words the change in ratio is more pronounced in the wide ratio transmission.
Wide ration transmissions are usually used behind engines with a narrower rpm band, like diesels.
Old Mar 3, 2009 | 07:48 PM
Mike8623's Avatar
Mike8623
Well I guess what I am getting at is: if I have a pto unit off a 460 CI 42 tranny......will it work on my 7.3 47 tranny?
Old Mar 3, 2009 | 09:43 PM
believer45's Avatar
believer45
Diesel_Dirk, I think it is the other way around. Close ratio has the ratios closer together so the change in RPM is less at each shift. Wide ratio has the ratios further apart so you drop more RPM on each shift.
Old Mar 3, 2009 | 09:56 PM
Diesel_Dirk
You're right...was thinking one thing and typed another.
Old Mar 3, 2009 | 10:11 PM
believer45's Avatar
believer45
Figured that was what happened.
Old Jun 6, 2009 | 01:58 AM
chubyboy's Avatar
chubyboy
i have a 1990 7.3 IDI...do yall reckon its the close or wide gearing?
Old Jun 6, 2009 | 11:09 AM
NWBronco's Avatar
NWBronco
It's about your intended use. Winding it out, not under much of a load, wide ratio. The engine does not have to start over at a lower RPM. More of a gasser thing, as they make torque at a higher RPMs. The close ratio is for the big load rigs, where the drop in RPM may cause you to lose wheel speed. Wreckers would normally have a close ration, they'll pull loads that are heavier than they are. You can listen the 18 wheelers gearing up under load. The RPM bearly drops as they shift-shift-shift to get the 80,000 lbs a movin'
Old Jun 13, 2010 | 06:03 PM
millertime2605's Avatar
millertime2605
I heard that the input shafts are different between the two. Also heard that the bellhousings are a different bolt pattern. Can a 47 take the place of a 42 without any modifications?
Old Jun 13, 2010 | 06:20 PM
Brown Falcon's Avatar
Brown Falcon
The 42 and 47 are interchangable without modification.
The gas version has a different bolt patter than a diesel version so they will not interchange.
Old Jun 13, 2010 | 07:14 PM
redman84's Avatar
redman84
x2 I just had this conversation with my tranny guy. He said that the cases are absolutely interchangeable from bellhousing to tailhousing as long as they are from concurrent motor types and drive types.
Old Jun 13, 2010 | 07:47 PM
TheTowingCowboy's Avatar
TheTowingCowboy
in a 9 speed the RPM drop is about 700 RPM's atleast the way I drove the truck that was about the average drop was 700 to 1000.
