Boost Leak Detector???
Old Mar 3, 2009 | 05:45 PM
PsD007.3's Avatar
PsD007.3
whats the easiest way to build one?? do have a local ACE hardware store, just wondering whats the easiest way to build one and what would i need?
Old Mar 3, 2009 | 06:10 PM
ron's power stroke's Avatar
ron's power stroke
45* 3" PVC coupling..a plug for one end..a rubber boot 3" to a 4" for the other end..air reg and air fitting...glue plug on one end..drill and tap for air reg with air fitting for hose..scuff the othe end of the 45* with sand paper..clamp on boot...
Old Mar 3, 2009 | 06:12 PM
ron's power stroke
Old Mar 3, 2009 | 06:29 PM
PsD007.3's Avatar
PsD007.3
ok i never thought of using the boot thats already on the turbo i was going to clamp it directly on the turbo..can i just get a cap that fits in the boot already on the truck and just clamp the cap in the boot...and tap the boot for the air fitting??
Old Mar 3, 2009 | 06:33 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Make sure you dont put alot of PSI into it, I keep it under 30psi. If you go to high you will blow somthing apart.
Old Mar 3, 2009 | 06:35 PM
ron's power stroke
tap the cap..the boot wont hold threads..be careful using the stock intake tube..there not made for PSI..there made for vacume..i have a spare tube..thats why i use it..you could split it when adding PSI..a 4" down to a 3" boot right to the turbo is much better if you dont have a spare tube..ive had mine up to 40 PSI a couple times..the tube swells right up lol..keep your head out of the way in case she deside to pop off..
Old Mar 3, 2009 | 06:54 PM
PsD007.3's Avatar
PsD007.3
soo i could use the stock tube??and take it up to 25 psi??
Old Mar 3, 2009 | 07:01 PM
ron's power stroke
20 should be plenty but you can try 25..bring the pressure up slowly..you will need to find a way to plug the hole where the green tube from the map sensor is though..
Old Mar 4, 2009 | 12:09 AM
PsD007.3's Avatar
PsD007.3
ahhh screw it looks like i'm just going to buy a rubber coupler house and a pvc cap and just do it that way...on my stock turbo what OD is the turbo inlet???
Old Mar 4, 2009 | 12:48 AM
ron's power stroke
stock turbo is 3 inches..
SturgeonHunter
May 19, 2011 12:11 AM
corexradnar
1997 - 2003 F150
15
Nov 20, 2010 07:18 AM
bwoldschool65
Garage & Workshop
21
Jan 27, 2009 09:38 PM
tscryba
2004 - 2008 F150
Aug 31, 2004 07:22 PM
Soonerz75
May 23, 2004 01:51 AM
