Highboy power steering
Old May 28, 2013 | 04:57 PM
  #76
bajafishnut's Avatar
bajafishnut
I will download some photos to photobucket soon, and see if I can post them here for you. I ended up with a 78 F250 4x4 box, looks like the one you have pictured, but did not use it. I scored a rebuilt box off Ebay, for under $200 as I remember. It mounts to the outside of the frame, lined up with the steering, but had to shorten the connecting shaft, and the drag link. No problem, with either, and some schedule 80 pipe the right siZe. I flipped the pittman arm 180 deg, and it all lined up sweet. Works fine, misses the left front tire (and they are 325x75x17 Mickey Thompson Baja's.. so they are fat fat fat.. now let me see if I can download and post some photos..
Baja
Old May 28, 2013 | 05:21 PM
  #77
bajafishnut
OK, 2nd attempt, I have them in photobucket... now??
Old May 28, 2013 | 05:23 PM
  #78
rottenstock's Avatar
rottenstock
Kind of a small picture but it is there. Can you inbox me the photobucket link?
Old May 28, 2013 | 05:27 PM
  #79
bajafishnut
I will try... but have tto go soon, so tomorrow early am might be better for me... but will try now...
I am at bajafishnut1 at photobucket, can you find them from there??
Old May 28, 2013 | 05:29 PM
  #80
bajafishnut
one more
Old May 28, 2013 | 05:33 PM
  #81
rottenstock
I saw them. I'll look at it.
  #82
bajafishnut
Old May 28, 2013 | 05:41 PM
  #83
bajafishnut
I headed back to photobucket to download more...want to show you the drag link and pittman arm... Oh, I used the Saginaw (canned ham style) pump, and made my own brackets... Now I, with ND's help, found some stock brackets off E250's... and ordered them. Hey, he has been a continual help to plenty of us, and without him, we'd be way behind. Kudos many times over ND.
Baja
Old May 28, 2013 | 05:57 PM
  #84
bajafishnut
Old May 28, 2013 | 05:58 PM
  #85
bajafishnut
A bunch more on photobucket now...
Old May 28, 2013 | 06:03 PM
  #86
rottenstock
Awesome. Thanks for the pictures. I still gotta pick up the drag link and the plate to weld.
Old May 28, 2013 | 10:13 PM
  #87
bajafishnut
I welded spacers inside the plate, for the bolts to go through, and give the gearbox something thicker to bolt to. I also welded the plate to both the top and bottom of the frame, but not to the edge of the top or bottom, but about 3/8" in from the edge. You can see in the photos. With the gearbox on the outside of the frame, the pittman arm does not have to pass through the space between the frame and spring. Also, since it is not a cross over system, nothing has to pass through in that space. Works for me..
Good luck amigo, and keep us up on your progress..
Baja
Old Jun 1, 2013 | 07:47 PM
  #88
rottenstock
Baja,
Did you cut/weld that drag link?
Old Jun 1, 2013 | 10:41 PM
  #89
spikinfool05's Avatar
spikinfool05
if you think the steering box you got needs rebuilt. use it as a core and get a readhead rebuild it is something you will never reget.
Old Jun 1, 2013 | 10:49 PM
  #90
rottenstock
No one has told me how much those RedHead boxes cost. So I think for now, i'd rather just run the one I have, especially since I still have to mark everything up and drill some holes.
